As you can see, with them all turn down, the gain knob (top left) is not in the same 7 o'clock position as the other 2, I want to make it all line up the same, there is a screw on the knob, does anyone know the size of the allen key that i need to loosen it to readjust?
And is this the best way to do it
Thanks
Before you do this open up the back and check that there are wires to the pots. If they are soldered to the PCB you need to desolder these first.
Or just live with it....
seems a bit OCD to me as none of the knobs on a Klon are going to be on Zero anyway...
that said if I'd made the pedal I'd line them all up and probably commit Harakiri if the jacks were wonky
There is a screw on the side of the knobs, yup, I will try and loosen up to see if i can adjust it. If that doesn't work then i'll just leave it. Not a big deal.
Thanks, I'll take a photo and show you tonight, I think it is Allen but will need to make sure. Appreciate it
in a range of different colours
as others said i'm pretty sure it will be a normal little grub screw, if you dont have a little screwdriver should be able to get a set from any highstreet hardware store type place, or a crap set from the pound shop
just set it like you have, loosen it a touch, turn and retighten
