I’ve recently acquired a lovely ‘98 Epi Black Beauty in a trade, and it’s currently set up with a push/pull to bring in the middle pickup independently at any switch position, which is great.
However I’d also like to coil split the bridge pickup - is it worth adding a second push pull to do this, or could I theoretically use the existing middle pickup push/pull to add the splitting wires to, so when I pull it up in, say, the bridge position, it would add in the middle pickup and coil split the bridge at the same time?
I suspect I’ll need to install a second push/pull pot but I’m happy to be told otherwise? Thanks!
Much more practical to have them separate though, and more reliable
Instagram
The stock wiring on the PRS Swamp Ash Special splits the neck pickup and adds the middle at the same time with one switch, and I've modified mine with an extra switch for exactly that reason.
You could then use the split switch to split two of the pickups at the same time - bridge and middle may be the most useful, especially if the neck is a relatively low-output PAF-type. (On my PRS I've done bridge and neck.)
1) Freeway 3X3-03 six-way toggle switch, wired to select assorted useful pickup combinations.
2) The Peter Frampton circuit.
Neck and Bridge pickups via selector switch, then, the upper Volume and Tone controls. Middle pickup via the lower Volume and Tone controls.
This permits blending or the middle pickup on its own.
There was a limited edition Frampton LP Special with this circuit and three P90s.
3) Epiphone SG400 Custom circuit.
3V, 1T controls. Again, the selector switch offers neck/both/bridge. The middle pickup is blended via the third volume pot.
