Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
I recently got a truechannel style jig, which I think should work, but am yet to try it for this
Instagram
https://guitarsandwoods.com/binding-routing-jig.html
Question is, is there enough of a side on a drop-top for the bearing to run on?
I've tried the Stew Mac version of that and it doesn't work on droptop's. I think it could be modified to do it but as it's not mine I'm a bit reluctant to modify it.
I have the small dremel attachment from stew mac too.
https://www.stewmac.com/luthier-tools-and-supplies/tools-by-job/tools-for-binding/binding-router-guide/
Absolutely hated it at first, but now I have practiced with i find it a good backup for the trickier spots, although a bit of tidy up with a knife and chisel is often needed
Both should work reasonably well with a subtler bevel, both will struggle with a deeper one.
Instagram
Instagram
