For my kit-based 12-string Tele build, I'm considering reprofiling the (maple) neck. It's quite chunky, and I'm thinking that offsetting the profile so that the deepest part is biased towards the bass strings might be better. Not intending to make a V shape, just offsetting the C shape a bit.
My first thought was to tale a belt sander to it, one of these, which has an unsupported belt, so has some give...
https://www.machinemart.co.uk/shop/product/details/cbs1-5-belt-disc-sander
It's a 1" belt and can be used for some fairly delicate work (shaped a knife handle with it, which came out rather well).
I guess there are probably proper luthier-style techniques that one might use instead. Any suggestions?
Nomad
(For reference, I have tried a spoke-shave, a belt sander, a small orbital sander, rasps, files, sandpaper, etc. when making a neck.)
Nomad
Instagram
Thanks very much chaps. I think it makes sense to try the gentler method first and see what the rate of material removal is like (belt sander is probably a bit over the top). So, some cabinet scrapers would seem to be in order.
I was looking at these a while ago...
http://www.ebay.co.uk/itm/High-quality-miniature-micro-cabinet-luthiers-scraper-4-piece-set-/181319204220?pt=LH_DefaultDomain_3&hash=item2a37777d7c
...mainly because one of them has concave edges. I gather they're quite small - maybe 2-3" long, so are maybe more suited to small spaces. No idea if the quality is any good (less resharpening is good, I guess).
I notice that Andy used a straight one - is the concave thing really needed?
Any suggestions for good quality scraper (or set)?
Nomad
Instagram
Instagram
Got some scrapers yesterday, but haven't touched the neck yet. They're Footprint ones sold by Machine Mart, which are presumably decent quality.
I had some practice on a bit of 2x4 softwood, but only managed get dust and some very fine fibres - nothing like ribbon shavings. Might need more practice or learn to sharpen them. I tried the file thing, but it didn't help much. I'll do some searching and find out more about sharpening methods.
I'm not too fussed about finish as long as there are no gouges and any faceting is mild. Quite happy to sand the last of it.
Nomad
Instagram
Just been practicing on a bit of meranti, and made some progress. I was still getting dust at first, but found that holding the scraper a bit more vertical helped - about 60-70 degrees. Also, a bit less pressure and a bit more speed. I tried rounding off the corners and did okay, although it seemed that there was a good direction on each edge, and the other tended to snag - I guess it depends on the line of the grain at the surface being worked. On the first pair of edges, after sanding, the rounded areas had a bit of a ripple feel when I ran my finger along. I did the other two edges with lighter and faster strokes and they had less ripple.
Not quite ready to start on the neck, but I think I'm getting a better feel for the tool.
Nomad
Nomad
Has anyone got any idea of the ball park figure this would cost please?- when I say ball park I mean is it going to be closer to £200 than £800 as when it comes to substantial and time consuming woodwork I have no idea of the labour rates and time involved. To complicate matters it has paint deep enough to swim in, but the whole instrument will be refinished in the future.
Thank you
