Thanks
- Use one preset for a whole song or set of songs.
- Configure the top tow for 4 effects
- Configure the bottom row *not* to change presets, but instead to send midi program changes
This will give you control over the amp across the bottom row, and control over the effects across the top row. You wont be able to change channel and change the state of the effects at the same time, so if you do any of that you'll need to press two or more switches in a row.
You *can* run it the way you're suggesting, by using a preset per-change. But you will get a small gap of silence when you change presets. If you can put up with that, then groovy.
The other suggestion I have is a Boss GT-100. It can do what you want and doesn't have a gap of silence. If you need tap tempo for delays though, you should be warned that they go all pitchy and wobbly when you tap the tempo.
I've been around this particular circuit many times before, as have a bunch of us, so you're in good company for advice!
Yeah i used to use a dl4 and a dd20 at the same time and noticed a difference in taps
