Strymon El Capistan V2
  • NickBNickB Frets: 266
    Dumodal said:
    NickB said:
    If you want to up your sights to a Volante, the reverb is definitely independent from the delays. It's also generally excellent.
    Thank you for the suggestion but I’m looking for delay/reverb combo that is compact and set and forget.
    What about the Source Audio Collider? I set up mine and never touch it again unless I need other pre set, it's not expensive but I think its better than the Del-Verb in terms of functionality and design.
    I had one momentarily but it was a noisy hissy thing so it went back. Maybe it was just the one I had. And it has more functionality than I need. Mine is a simple requirement. Tape delay with a tap tempo and a spring reverb that I can leave on permanently.
  • HootsmonHootsmon Frets: 16007
    You can't do midi on V1?
    tae be or not tae be
    Hootsmon said:
    You can't do midi on V1...can you?
