OCtave pedal
mike_lmike_l Frets: 5700
A few years ago I had a DOD octave pedal. I got rid due to it needing a weird power supply (IE not a standard centre-neg 9v).
However the unit sounded awesomes (when battery powered).
I've had the Boss ones which didn't sound quite right - actually sounded horrible to my ear....
What octave pedals sound and play nicely without being massively expensive
    edited October 2014
    Micro Pog is my choice (great tracking), octave up and octave down.....is that what you need, or are you after double octave down?
  • mike_lmike_l Frets: 5700
    Just single octave down. That's what the DOD had, and it sounded awesome into a dirty Marshall. It also worked well with bass.
    And despite the booklet saying don't use with chords, sounded fantastic with chords (at least powerchords).
  • Ehx fork coming out soon... ;)
    Did you try an oc2 or oc3? The oc3 sucks. Apparently, the oc2 is a bit glitchy but sounds much nicer - maybe not right for you though.
    Or this.
    http://www.morpheusguitarpedals.com/droptune.php
    Don't know about power for it, just remember hearing it was good at that. Not sure if it does a blended signal either mind...
    Had both the OC" and OC3, and both sounded meh/crap.
    The Morpheus is an alternative to carrying a second guitar for using a drop-tuning (IIRC).
  • The tracking on the Micro Pog is great - I'd say go for that, or wait for some Pitch Fork reviews if you fancy the functionality that has.
  • ICBMICBM Frets: 73101
    edited October 2014
    The DOD will work fine on a standard power supply with a converter cable - it's only the jack which is different, not the supply polarity.
    There is a second generation of these DOD pedals which have a standard power jack, but I'm not sure the Octoplus survived long enough to get it - I can't find any pics of one.
    That's the kiddie. I wish I'd kept it now.  :((
    For me, it was the perfect octave pedal......
  • it can be had for £20 - £30 quite often on ebay fella
    I don't have an Evilbay account......
