I've become totally addicted to the Matchless Channel 1 & 2 emulations in the Helix.
This has got me pondering, unfortunately for me, pondering generally costs money.
Now I do not have anywhere near the dollar required for a Matchless, so that's off the table. But a ballpark amp would be of interest.
I've come down to a few options.
1. Just stop now and continue to enjoy the Helix versions, they're blooming good.
2. An AC 10, 15 or 30? Worried that the lovely cranked sounds won't be achievable even at gig volumes anymore though.
3. Maybe the UA Ruby (but is this any different really to the Helix?)
4. Maybe a Ceriatone Muchle$$ DZ 30? But importing from the States likely to also be horribly expensive.
5. A Bad Cat or Morgan....but which?
6. Something else? A pedal (Big Trees?), a different EL84 amp that'll get in the ball park? I love the snarl of it, especially channel 2.
Any suggestions?
Or the amp itself?
"I'm so happy with the thing I already have, that I'm thinking of changing it..."
If you're really happy with what you have why get something else?
But seriously, a Badcat is the closest you can get and pretty cheaply sometimes too.
Had an AC30, replaced it with a Matchless DC30 to find the ultimate Vox AC30 tone. That turned into several other Vox-like amps including another Matchless and a few Cornells.
Many thousands of £ later, it turns out the ultimate Vox AC30 sound is a Vox AC30.
The Matchless sound to be is much harder, more dynamic and less forgiving than an AC30. A lot to do with the massive filtering, the mismatched output transformer and the choice of speakers. I think the only other company that does this is Bad Cat.
A Bad Cat Black Cat 30 (non reverb) is the same amp as a Matchless DC30 and usually goes for considerably less on the used market. Still not a cheap amp though. You'd be looking at £1500+ minimum.
Live they have to be heard to be believed.
I've got an 01 black cat 02 lightning and a Morgan and all sound similar. For not gigging you need pedals which I'm not listing as that's another rabbit hole.
The AC30cc series have a 1x12 model. I got one of those, modded it to run on 2x el84s, put nicer transformers (still rated for ac30 power levels) magical mojo caps and resistors in key areas and left everything else the same. To my mind, that's basically into the matchless camp - oversize transformers and ghosts haunting the coupling caps. I usually compensate for the impedance mismatch that results from pulling half the power valves, but discovered that the impedance mismatch sounds glorious (thought the 1972 celestion silver alnico that produced it might have something to do with it)
The total cost of amp and upgrade parts, excluding the old speaker, was about £650, but obviously does require soldering/ circuit knowledge.
Bandcamp
Spotify, Apple et al
