https://www.thefretboard.co.uk/discussion/250977/wtb-fryette-ps-2
It's not an attenuator, per se...the PS-2 is a clean 50w amp which acts as a 'slave' for your main amp.
On the fan, I stopped noticing it after a while. Plus, if you want to play so quietly that a fan would intrude, you have the option of running the line out to IRs and studio monitors/headphones. The Power Station doesn't need to be powered for that use case, so no fan.
My Sequis Elemental does an equally good job - and it is silent.
There is the instant fan noise as soon as you switch it on, but in a rehearsal/onstage that is never an issue.
It’s a superb bit of kit and one I see keeping for a very long time. Not used it as an attenuator yet though, although I don’t think I’ll ever use that bit.
I adore the unit. It is the only way I get to crank my Master on most of my amps, living here in London, let alone dime them and hear tones I otherwise would not get at with just their own MVs. I play a Bogner Shiva, Suhr Hombre, and Friedman Dirty Shirley Mini thru it (though the latter really has such a good MV I sometimes turn off the Fryette entirely). I even hope to get a pre amp at some point and play straight into the PS2. . .
Put me in the unfashionable camp of 'Highly recommend'.
I use it as a power amp for my HX stomp and/or with a revival drive as a preamp.
Also use it as an attenuator for my valve amp and I think it sounds great. I also use it to add an fx loop which my amp doesn’t have.
Ebay mark7777_1
