I haven't changed a valve in my Fender since I got it in 2017 and that's about 300 gigs ago. There are some amps that push the valves way too hard but in most valve amps with sensible circuits the valves won't need replacing for hundreds of gigs.
If you want a Tonemaster because it's light then yeah, they are much lighter in comparison.
As Danny says, don't buy anything with that kind of cheap, under specced power section for reliability, because they're not.
Tonemasters are a great compromise if you need something light to sling in a car boot, but if it's just for home use it's a tonal compromise you don't need to make.
My TMDR has been flawless and even if the power section is in some technical way 'under-speccd' it's incredibly capable in a gig situation. Played a gig just this Thursday. Small room, 5 on the normal channel volume and set to '1 watt' mode. Plenty loud.
But it's the transformers that are the big, heavy and expensive parts unfortunately
Because a conventional solid-state output stage has high damping. However, solid-state amps with purposely low output damping - which can be done, but would normally be considered bad design, for PA, hi-fi etc - can have a pretty valve-like sound and response.
Not really - especially if you're just going to use an output transformer, you can use a switch-mode power supply if you want. An output transformer only weighs a few pounds, even for a fairly high-power amp. For up to 20W or so it's only a couple of pounds at most.
Surprisingly, the heaviest part of a conventional valve amp is usually the cabinet - especially for a combo, but even for a head. Speaker magnets probably come next, so a lightweight pine cabinet and neodymium speakers will save a lot of weight. That's really why the Tonemasters are so light, more than not having transformers.
Have a listen to this...
As Danny says you don’t have the big output transformer, so it won’t sound identical, but you do get a proper cab and speaker which makes a huge difference next to cheaper-made amps (including some that cost more..!)
To my mind - and to elaborate on may earlier post - the point is not to kid yourself that it's literally identical to the Princeton/Deluxe/Super/Twin when compared directly, sat next to each other in a context you can turn the valve amp up to proper volume. They're probably >95% there, but not 100% and that's fine. Where they win is on all the other features:
- They weigh half what the valve versions do
- They have built-in attenuation that is really really useable, which means
- They have built-in DIs with independent volume controls which is an absolute boon for real-world use on stage & in-studio
- They work as USB interfaces as well
- Did I mention they weigh half?
If you only play at home and don't record and can turn up plenty loud and never lug it up a fire escape at a venue then it's not going to be worth it. But if more than 1 of that list is useful then they're a game changer.That all said, this is obviously just one situation and doesn’t get anywhere near proving that all swans are black! In fact, it proves absolutely nothing :-).
Power transformer can be switchmode like the St James but I hope that doesn't become a thing ... because if it does then repairing valve amps is going to become a lot more time consuming and complex. I've got a valve amp in at the more with a SMPS for the low voltage side but being low voltage it's a common module and only £40 to replace.
What you get with any audio transformer when pushed a bit, that I think makes a difference is the non linear in regard to frequency distortion from the transformer. it just sounds more pleasing to my ears on more complex chords than any SS design I have ever played.
I like the Peavey Transtube amps, recorded a few at 2020 and for single note stuff and roots and fifths you would have a job to tell but more complex chords with thirds and sevens tend to sound better with literally any decent valve amp to my ears.
I agree that it 'proves' nothing - not least because we aren't the player, and the response (rather than the tone alone) is more noticeable when you are - but in fact, the player himself says that he might have struggled to tell them apart if you couldn't see which was which.
Interestingly in the results video he also shows that the Peavey has an Eminence Texas Heat in it - I've recently put a Li'l Texas (the neodymium version of it) in mine, which sounds even better than the Celestion I had in it before. These amps are very sensitive to the speaker, much more than solid-state amps usually are in my experience... which is another feature of low output damping.
Yes, my point is that I think it's a myth that valves have a 'magic' sound which can't be duplicated by some form of solid-state technology - it's just that the reasons for it are more complicated than most people think, ie it's not actually the valves that are the important difference. And I really do think that analogue solid-state is probably the most reliable and most practical solution, and can sound as good as valves if done correctly - which until fairly recently, amp designers have somehow missed.
I've seen comments previously about digital "ss" vs Analogue ss - I think SS purists distinguish themselves from the tone master serious on the grounds that it is very advanced digital processing rather than SS. (which I think was where @ICBM was going in the previous post about well designed analogue SS)
But I'll admit at this stage, I'm at the outer reaches of my understanding of the subtleties!
FWIW, I had a Deluxe Reverb TM and absolutely loved it. Regret selling it (sure I've said that before!) but it was superb and their implementation of the trem and reverb really was fantastic. Agree with previous comments about response, but not sure I'll ever be good enough at guitar to use that as an excuse!
