I have the Yamaha MG10 mixer I use for online lessons to mix my sounds that I sent as a stereo output via XLR - XLR into my Focusrite 8i6. I've been using this for about 2 years now.
I've only just realised though if you use an xlr (male) input then it actives the microphone preamps and it adds unnecessary gain and distortion if you're not careful as its a mic signal which is hotter than a line signal via 1/4".
I did a test to see if I needed any preamp gain with a TRS cable going from the mixer (XLR female from the stereo output) and I do need to add a bit on the Focusrite to get some decent volume.
Is it better to use a line 1/4" input and raise the preamp level or stick with a mic input and have no preamp gain at all? As when I use xlr in I don't need any.
If you pull down the master on the desk though so nothing clips it will be fine ... also check if the inputs have a pad switch ..that will also lower the signal level before anything clips.
Or use the line inputs on the interface which are generally -10 to 0dB in sensitivity anyway
There is a pad function on the interface, though in the time I've been using xlr in its not clipped too much. Only lightly.
I’ve seen Boss have released a Gigcaster which is similar but again skeptical if it’ll do 2 way monitoring.
