I’ve had this for a while now but I never really got round to using it so thought it’s time to move it on:
Please see the link below for stock pics (this one is blue / grey not black).
The updated model is retailing for £200ish
£65 postedhttps://www.bhphotovideo.com/c/product/740833-REG/Mono_EFX_PDR_BLK_EFX_The_Producer_Messenger.htmlHighlights
Holds DJ Gear and Accessories
Fits Laptop with a Screen up to 17"
Waterproof Sharkskin Shell
High-density Padded Interior
Industrial Rubber Sole Bottom
Steel Rivet Reinforced Handle
Shoulder Strap with Memory Foam Pad
Features
The Mono EFX The Producer Messenger Bag (Jet Black) is designed to shape-shift from headlining DJ to digital photographer, to audiophile to CEO. It has a laptop compartment with restraint strap that fits a computer with a screen from 12-17". There are 2 removable dividers that allow for custom configurations. Remove 1 divider to fit portable sequencers and mixers or remove both dividers to fit documents, notebooks and magazines. It has two 2.0" deep, zippered, padded front pockets that can fit a Serato interfaces, processors and hard drives. It also has deep side zippered pockets for wallet, cell phone, AC adapters with a key clip and a document pocket for files, folders and airline tickets.
The bag is made from a waterproof, 100% animal-free Sharkskin shell that provides extreme resistance to abrasion and the elements. It has a high-density padded interior and an industrial rubber sole bottom. It is carried by a steel rivet reinforced handle or a removable adjustable shoulder strap with non-slip memory foam pad.
Messenger Bag Basics
- Holds DJ equipment and accessories
- Laptop compartment with restraint strap fits a computer with a screen from 12-17"
- Two removable, padded dividers for smaller components, remove 1 divider to fit portable sequencers and mixers or remove both dividers to fit documents, notebooks and magazines
- Zipper-less flap design creates a rainproof enclosure
- Slim profile designed for airport and subway travel
Material
- Waterproof, 100% animal-free Sharkskin shell provides extreme resistance to abrasion and the elements
- High-density padded interior
- Industrial rubber sole bottom
On Board
Meets current FAA specifications for carry-on luggage
Specifications are subject to change; always check with the carrier
Pockets
- Two 2.0" deep, zippered, padded front pockets fit Serato interfaces, processors and hard drives
- Deep side zippered pockets for wallet, cell phone, AC adapters with key clip
- Document pocket for files, folders and airline tickets
Carrying Options
- Steel rivet reinforced handle
- Removable, adjustable shoulder strap with non-slip memory foam pad
![](https://i.imgur.com/fKZv9rR.jpg)
![](https://i.imgur.com/GKn1kwu.jpg)
Good deals with: handsomerick, majorscale, gassage, sticker, smudge_lad, anglian, edinfield99, thewiddler, thomfripp, notonlybutalso, JDE, chebellanga
