You can even do that on digital modelling amps, on the Boss Katana for example you can put a drive pedal on and still have amp gain.
please correct me if I’m wrong
Redplate BlackVerb
Ceriatone / Dumble ODS
One knob seems so much simpler (despite the trouble mine has gotten me into over the course of my life)
Apparently, they "feel" different!
The trimmer control could just be two resistors inside the amp pre set by the amp builder.
The trimmer control is probably a set and forget type control, but if you have ever bought an amp and the drive channel has way to much gain or not enough, you would wish you could change the internal gain - with this set up you can.
The standard input volume / gain sets the amount of attenuation between stage 1 and 2 (Valve 1).
Then there is a trimmer or rear volume pot to control attenuation between stage 2 and 3 (Valve 1 to Valve 2 )
Then there's the Overdrive control (front panel) that attenuates between stage 3 and 4 which is followed by the (Ratio / level control) that acts as a Master Volume for the Overdrive signal only. It's simply a volume pot at the output of stage 4.
There's a lot of signal gain available when you cascade 4 ECC83 triodes together. The various controls allow more control at various stages in the signal chain preventing too much clipping from taking place in one part of the chain.
When you say 4 triodes, does that mean two ECC,83 valves and you are using both sides of each valve?
