Helix on a budget.. Donner Arena 2000
£228 witb their additional 5% discount.
A lot of pedal for very little dosh indeed.
Anyone on here own one?
  • jellybellyjellybelly Frets: 793
    edited August 2023
    I didn't think it sounded great, but that might just be me? I have an allergy to 'sponsored content' though so my opinion should be taken with a grain of salt.
    A more skeptical man than I might deliberate what percentage of the development of this product was the reverse engineering of the software and hardware of similar products made by US and Japanese companies.
    Not me however, I love Donner...
  • thecolourboxthecolourbox Frets: 10260
    Jesus that's a lot of reverb and delay for no real benefit
    I'm scared and I'm waiting for life
  • Looks like the same FX unit that's available in various boxes and brands from Amazon and elsewhere.
  • welshboyowelshboyo Frets: 1831
    edited August 2023
    I don't think it helps that the guy is not a great player.....
    edited August 2023
    He reminds me of the kind of person who works in a guitar shop, and when you ask him if you can try out a guitar/amp he says yes sure then proceeds to play his own overly percussive style through it at a totally different volume and gain level than you'd like to try, while you stand and wait for your chance to actually have a go
    4reaction image LOL 0reaction image Wow! 1reaction image Wisdom
  • ReverendReverend Frets: 5400
    The video just sounds like being a guitar show as 35 people try various amps and pedals at the same time
  • RockerRocker Frets: 5088
    The guy demoing the pedal has a channel that teaches guitar playing.  His channel crops up frequently in my YouTube listing.....
    Nil Satis Nisi Optimum
    Thanks for the warning ;)
  • monquixotemonquixote Frets: 18207
    If anyone is after budget modelling the Nux stuff sounds excellent and supposedly the Hotone stuff is also very good.
    If that skeptic were back in the room, he'd be interested to discuss whether there were really 4-5 well-resourced and above-board guitar effects r&d departments for these companies all located in Shenzhen, China. Maybe it's some sort of new Mecca for innovative guitar equipment??
    (he wouldn't be upset at the user's of such though, each to their own)
  • WazmeisterWazmeister Frets: 9962
    Not for me, doesnt sound great…. In fact, the Bogner sound was woeful. As was the AC…
    Get a useD HX Stomp.
  • SporkySporky Frets: 29784
    I wonder if it's like the AV world. There are a lot of conferencing bars - basically USB soundbar with a camera and mics built in. From all sorts of companies.
    Many of them were designed by the same roving band of designers, incorporating a bit of the individual companies' technology (fer instance if they have their own audio or camera technology).
    It's entirely possible that the same happens with guitar DSP stuff. Line6 and Boss have their own developers I'd bet, but some of the smaller companies may use roving freelancers.
  • DrCorneliusDrCornelius Frets: 7509
    I went through a phase of buying loads of cheap mini pedals , nearly all Mooer, Nux and Donner. During my research I’m sure I read somewhere that they were basically all identical units with different finishes and logos
  • Danny1969Danny1969 Frets: 10880
    That is the case for a lot of things now. I have seen loads of active PA speakers with the same internal class D amps. EV, for example has a lower end range which is just one of these modules stuck in a polypropylene enclosure with an EV badge on it. Generally the RMS power is exaggerated, the size of the bridge rect, flyback tranny and mosfets are about right for 350 / 400 watts or so not the 1000W you see on the box.
    The earlier days of laptops, when I was heavily involved were also very incestiest. 2 large companies Quanta and and Compal along with Twinhead and a few others were basically making all the Dell's, HP's and other big brands. The HP Omnibook 2100 was basically the same laptop as the Dell Inspiron 3200 for example.
    The Icepower audio modules, which are a combined SMPS and class D power amp PCB are used in loads of audio products from B&O sub woofers to hi fi audio amps and as I've mentioned loads of times Fender Tonemaster amps.
    I suppose it allows designers to bring out a product quickly due to the lack of time and money needed for R&D .. plus all the certification is done. It does mean though that going forward there will be less innovation in the audio world.
    One company that is still designing all it's own products is Blackstar. When they brought out the Amped module I thought it was another generic amp module with some BS DSP in a box  but then coincidently I was mixing a U2 tribute a few weeks later and the guitarist was BS's head of design. He told me they designed it, and the St James amp completely in house which is nice to hear  in these days of other manufacturers using generic building blocks.
    There was a set of gut shots of AV mini power amps. Even the QSC ones were made from the same 3rd party modules as the cheapies.
    Extron had their own design. About a quarter of the capacitors, much higher efficiency, lower noise, faster startup ftom standby.
  • KebabkidKebabkid Frets: 3394
    A friend is obsessed and buys all these type of cheap sub-£200/mini-units and mini amps and then sells them if he doesn't like them and so I get to try them. The Nux ones were OK but the Hotone Ampero was probably the best. That said, he recently sold a lot of them and bought the Boss ME-90
  • steersteer Frets: 1228
    And there it is. If I were after a new multi fx, I would go to Boss, Line 6 or Zoom, rather than one of these lesser known models.
    The real Helix on a budget is the Pod Go. I mean it's the same amps and cabs and most of the effects of the Helix but available for £250 used on a good day.
    0reaction image LOL 0reaction image Wow! 8reaction image Wisdom
  • soma1975soma1975 Frets: 7122
    I mean, how many companies do you need manufacturing a type of weetabix? Better to have one do it to different price points or specs.
