First, put the old valves back in, making sure they go back in the correct locations - it matters with these amps, V2 is a different spec from the other two because it's a cathode-follower. If they're the original valves, V2 should be a Chinese-made one, with two bright chrome strips on each side of the plate structure. Don't put either of the other valves (most likely Tung-Sols) in this position.
Is the hiss dependent on the master volume and tone cut settings? If no, it's coming from the power amp. If yes, from the preamp. Is it on just the Top Boost channel, or both? Is it affected by the reverb setting?
Vox used to ship the CC series with Tung-Sols in V1 and 3, and a Shuguang in V2 - not sure if they still do, or why they didn’t just use Shuguangs throughout.
Yes, if you test them in V1 or V2 in the Deluxe it should show up any that are obviously noisy. The Deluxe doesn't have any cathode follower positions other than the tremolo oscillator (V5).
I have used JJ in cathode followers for years without issues, ICBM has maybe seen more in for failure, but it doesn't take into account the number in use I guess. Saying that, it is not my favourite valve for that position.
I'm going to rehearse with it next week and see if it warrants further investigation.
Brilliant info, thanks
