the laptop may be running on lower power consumption? also check if the computer charger is a bit older, maybe its not giving out as much charging power itself
I am not very intelligent. Can you tell me. If you plug your computer into a USB mains socket, will it charge?
http://www.screwfix.com/p/lap-13a-2-gang-switched-socket-usb-charger-port-black-nickel-flat-plate/26218
I think it's less a case of USB ports delivering less power these days, and more a case that modern gizmos have far larger batteries and higher charging requirements. Exactly. My Sony Xperia Z can't charge from USB at all - it requires more power to run than the 500mA at 5V (2.5W) a USB 2.0 port can put out. The Battery Charging profile allows for up to 1.5A at 5V (so 7W).
USB 3.1 can handle a *lot* more - between 10W and 100W depending on the voltage used (up to 20V, I believe). We're not there yet, though.
Interesting. I have a Sony Xperia T that charges quicker depending on the USB lead that I use. The Sony one that came with the phone requires the phone to be charging for ages. I have another, shorter lead that came with one of those portable rechargeable emergency chargers, and using that one takes significantly less time, for some reason.
