Was tooling around running my FM9 into the Fx return of my Friedman, so essentially using it as a valve driven power amp and cab. (Cab sims off in the Fractal)
Sounded pretty immense, and possibly a bit more “in the room” than through my usual FRFR setup. Plus, no IR option paralysis.
It got me to thinking about a Fryette Power Station and a 1x12 cab or something as a means of amplification.
But then I kinda took a step back and wondered how coloured the power amp section is in a typical amp?
I guess each amp is filtered slightly differently and the negative feedback will be different etc, but how MUCH different are we talking about here??
Is running into the FX return really colouring things that much? I’d assume the speaker will have more of an impact than the output section??
A clean power amp well below its maximum clean output doesn’t colour the tone that much - certainly not compared to the speaker and the cabinet. The power valve type has very little effect, contrary to popular belief.
If you push it to the point of overdrive then it starts to have a large effect - the transformer, NFB, valve type, phase inverter circuit type and values all make a big difference.
Interesting.
Thanks for the responses so far.
I wont be pushing the Power Amp into overdrive as that would kind of negate having all the modelling stuff beforehand.
i guess the main reason for the question is that this method still allows me to run direct to the PA with a cab simulated output in the Fractal, and have a more in the room feed to my amp behind me - negating the need for mics etc. I've found that I prefer most of the amp models in the Fractal when power amp modelling is switched on, so hence the question of cleanliness running into a non-saturated valve power section. It then means the models sound better going though the cab sims/IRs and hence PA, too. Win win.
Example, the Dumble model doesn't sound amazing running into the Friedman power stage with the power amp modelling turned off, but sounds rather awesome with the power amp modelling turned on, but seeing as I'm borderline anally retentive I don't want DOUBLE Power Amp going on, y'know.
Anyway, I could waffle on for hours about this stuff, and in particular, praise for the FM9. This method is essentially like changing the guts of my amp to the models I'm using, and it's all very amp in the room sounding seeing as you are getting all the filtering and directness of an actual guitar speaker and cabinet etc, rather than an IR
The feel is amazing, too, plus less faff with HPFs and LPFs when dialling in sounds for FRFR monitoring etc as the signal chain by proxy does all that for you.
The flexibility is huge.
I know it can sometimes be easy to over-think stuff like this, but trust your ears instead.
In theory at least it kinda seems a bit fruitless emulating a big, dynamic 100w 6L6 power section for it to be potentially negated by running it into a "smaller" 50W EL34 driven one, and whether the compromise ends up being a Dumble preamp circuit into an EL34 power section - which is a bit weird, topology-wise and compared to the classic circuit..
And I guess, ergo, whether a Fryette Power Station (or similar) would have a flatter response than one you would typically find in a regular guitar amp, giving a slightly truer representation of the modelled amp.
Seems like that might be a more negligible difference than I was expecting, though, which is cool, 'cos hooked up to the Friedman it does sound killer however you slice it.
Essentially, if the valve power section of the amplifier is pretty clean, the power amp modelling in the Fractal is more useful and means the model is more accurate, so hence my question being about how coloured you can expect a typical valve power section in a guitar amp to be.
All power sections are not created equal
Point is his FM9 may sound more immense through his Friedman amp because it is boosting the bass and low mids.
This is what I do with my Boss GT-1000 if I want an amp on stage as well as through the PA. I take a feed off the unit before it hits the cab SIM and put that into the FX return of my DV Mark head which runs a 2x12. I also take an XLR out, including the cab and mic SIM to the PA for FoH sound.
