Now, I have no idea why but I'd analogise this to a hot hatch versus a 5 litre Merc.
The Merc is a lot easier to drive at slow speeds than a Gti Turbo Twion Cam doo dah....it's long legged...
And that's the same with my other two amps- the Hiwatt and the Twin. Both are very long legged amps in a car sense, whereas the princeton, for all its wonderfullness, is an eager hot hatch wanted to go at 100 mph all the time.
Does this make sense or, as usual, am I talking utter tripe?
However the volume stage is very odd
There is a reverb send and return control and a pure return on the back which seems to control the master volume
I've never seen anything like it. Unless you turn the return up the amp is very quiet
I'm sure your mate knows what he is doing I'm just pointing it out because it's unusual and I have gigged that exact combo in a vocal pa only pub plenty of times and nearly killed people with it
It is incredibly loud for its size and wattage
Sorry Koss as you said
It's labelled return and not to be confused with the master volume on the front. I understand what they've done I'm not exactly clear why they did it that way. I'm sure some of the amp gurus will pipe in but I made the mistake initially of thinking that was just an FX return rather than the volume for the entire power amp section (which is stupid in hindsight)
