All,
I recently acquired a Bad Cat USA Player Series Cub 40R head, which is a terrific sounding amp.
After only 30 or so minutes of light use at home however it has developed a really loud mains hum that just will not go away. It doesn't do it on standby, only when flicked to fully on, and if happens whether a guitar is plugged in or not.
Before I take it to a local amp technician does anyone have any obvious suggestions what it might be, please? These are not cheap amps, it shouldn't be doing this, and I'm not happy at the thought of having to spend money on it already.
The sound quality is still in tact but the hum is obtrusive and very annoying.
I have already tried the following:-
- Plugged it in in different rooms around the house
- Different IEC lead
- Different speaker cable
- Different cabs and different impedances (the amp is switchable between 4, 8 & 16 ohms
Thanks ever so much in anticipation of any suggestions. I'll be out for most of the day today so please don't think I'm being rude if I don't participate in the thread again until later on in the day.
Valves can do this at any age unfortunately. Bad Cat amps also run them very hot, which doesn’t help.
I borrowed a pair from a Laney to confirm the diagnosis.
They sound good but are among the less reliable, in my experience. Any standard EL34 will do the job.
