Hi all
Quick question - got a lovely Orange AD15 1x10 from
@Kuras just this last week. Sounded great to start with but has had a bit of a wobbly in the past couple of days.
Basically, after around 15 min of playing the power had started to go down until it was whisper quiet. This happened a few times but coming to play it today and I get no sound. Observations:
- lamp still lights up
- can hear normal electric 'hum' from unit (not speaker)
- Speaker has no sound whatsoever, not even a hum/buzz
- Preamps and power valves (all JJs) glow up as normal/nothing unusual
- Rectifier (Sovtek 5AR4) does NOT light and is cold to the touch
- Both fuses are fine
I assume it's the rectifier valve, but having such little experience of amps with valve rectifiers I didn't know if this was normal behaviour - I thought they either worked or didn't, rather than failed gradually. Other thought was filament heater for the rectifier??
If it's the likely suspect, I'll get one of those plug in solid state rectifiers I've seen
@icbm suggest in previous posts about this amp.
Hopefully I'm not/haven't done anything to damage the thing!!
Thanks all
A plug-in solid-state rectifier will fix any of these faults though, so unless you really want to stick with a valve, I would get one in any case. It's probably worth having a very close look at the ends of the pins on the rectifier valve first, and see if you can see an obvious problem - if it is that, there will be a circular gap around the wire in the centre of the pin.
Incredibly knowledgeable as always @ICBM thanks for the troubleshooting list, will see how I get on!
Am is now considerably louder and lower noise - I'd have to guess on that evidence it was the valve gradually failing but we'll see. Think I prefer the tone now - low end is tighter. Would say it's a bit too crunchy (not on the good way) with the gain wound up now but it didn't sound it's best there before and I can't be certain the old valve was letting me hear what the amp actually sounded like before anyway.
Would love to take you up on your offer @ecc83 if it's still available so I can see what it's 'supposed' to sound like and have a spare as suggested - I'll drop you a pm.
Thanks for your help both!
My usual setup pedal wise is Hotcake > TS mini (gain 0, volune tone up around 2 o'clock) > Rat.
Enjoy!
