The yard is nothing but a fence, the sun just hurts my eyes...
https://valvetubeguitaramps.com/product/ps-vane-classic-series-ecc83/
The Tung-Sol 6V6 (which is what I usually match it with) is really middy, warm and creamy so they sort of balance out.
I found a couple of old valves in my uncle's radio valve stash- I've tried a Sylvania 12AX7 and a Brimar 6V6 and a Colomor (not sure what it is, I suspect rebranded modern-ish production- there were no markings on it) 6V6. I think the Sylvania 12AX7 sounded a bit more "vintage", though I wouldn't pay crazy money for one. The Brimar is awesome but again I wouldn't pay too much, the Tung-Sol 6V6 is still pretty darn good. (Granted at current prices you could argue that "even" a Tung-Sol 6V6 is pretty expensive!) The Colomor was pretty nice too but not as nice as the Brimar and probably not as nice as "even" the Tung-Sol.
Also what speaker are you using? Again looking at the whole picture is the thing I think.
EDIT: Oh I haven't got as far as trying a JJ 6V6 in my tweed Princeton- I sort of assumed it might not fit with the alnico speaker. I had a closer look the other day and I think it might, but I haven't got round to trying it yet. But based on trying it in my VHT and Fame Tube 5, I would think it's not the way to go... it's brasher, brighter, harsher, louder etc.. That sounds like I don't like it- I do, but for certain things. It does seem to help accentuate the Black Panel character of my VHT Special 6, for example.
It's the slight tweak to the treble and bass controls on the amp afterwards that confirms the valve has different tonal qualities as some require me to push the treble to bring back some brightness, and others I can hear a fuller midrange and low end, so although not transforming my amp into something else, I have a preference for certain valves in the amps I have owned for a while and know well because of how they bring out the favourable characteristics of the amp in question.
With so many comparison web sites out there, how do I choose the best one?
They do sound different, some are darker and some are brighter, the brighter ones tended to have slightly lower gain.
From Memory:
JJ were the darkest and lowest noise at the time, good for V1 positions, but you might want to avoid in a dark middy amp.
Chinese 12AX7B and 12ax7A were high gain but have good clarity, but you could go through several before finding one that didn't hum or pop etc
Was either Sovtek or EH that were the brightest and lowest gain, The worst valve in the whole lot was one Sovtek that was microphonic in V1, it was fine in other positions.
Saying all that the number one decision for me when putting in valves is acceptable noise levels.
I have had several JJs fail which has put me off them and old 60’s longplate Mullards get microphonic in anything high gain but they do sound very nice and airy/open on anything else.
Having said all of that:
There is a bit of a difference to be generated by valve selection, and it can be worthwhile if you have an amp where the controls don't seem to go far enough. For example, I have the (much-derided-by-ICBM) Cornford Harlequin, and with standard JJ or EH 12AX7s / ECC83s, everything was very middle-y and congested. I found a couple of Brimar 12AT7s (yes, not ECC81s) that I had bought for something else and ended up not using as they didn't have enough gain, and with those in both V1 and V2 of the Harlequin, everything is much clearer and more balanced. I wasn't using the last third of the gain control with the ECC83s, and treble was always at max. Now I'm around 3/4 on the gain and treble can be just above halfway.
Agree in general that noise is probably the most noticeable operating characteristic of valves. I like the old EHX ones (yellow print from early 2000s), and I've always had a thing for old Mullard or Brimar valves. I've had some success with things like JAN Phillips too, where I want less gain.
For me (and I appreciate this is a personal experience), JJs are the bog standard baseline, and I'm always looking at minor but real improvements from there. I like bright and present, though, so YMMV...
