Thinking about a clear out of guitars mostly partcasters.
These just don’t get played nowadays so it makes sense to try and pass them on.
All the partcasters need setting up to your preference. I’m not really sure how
to price these so I have put some prices I think are reasonable.
All guitars are collection from near Dudley, West Midlands.
Kit Built SG (Project) £100
This was a kit built guitar, sold to me as Mahogony (looks like it but I cannot confirm or deny).
Finished with Wudtone so has nicely aged over time.
Pickups from memory is a warman in the bridge and a unknown P90 in the neck (most likely a Iron Gear Alchemist 90) both sound great.
The pots wiring are still the cheap stuff that came with the kit.
Will need a decent set up.
Strat £120 will consider splitting up SOLD
This is a partcaster I put together a while ago.
The body was from memory was from Ebay sold as nitro finished. It is a satin finish but not sure its nitro, it wouldn’t crack when I tried the freezer treatment. It does appear to be fairly thin though. I have attempted a mild relic.
The neck I’m pretty sure was from Northwest Guitars. (Note I drilled through when installing the turners!) I think the wiring loom is also Northwest Guitars
Hardware is all nickel and the bridge is a Wilkinson, not sure on the tuners now
The pickups are Oil City Rocket 55s
Again needs a decent set up but works as it should.
