The only way I can think of to make it easier to set the boost volume would be to replace the boost slider with a normal rotary pot of a suitable value but that would be a fair amount of hassle. If the loop on your amp is switchable you could put a "lion tamer" style pot-in-a-box in the loop with the EQ and use that to trim the volume, then leave the pedal on and switch the boost with the loop switch - all a bit messy though.
These days I use multi FX for all my effects but when I used a pedalboard I had one EQ set for a volume boost and another set for a volume cut (scooped slightly). It is really useful for when you need to play a part low in the mix.
I love EQ. I could easily live a with just a few EQ pedals (pre amp and in the loop), delay and reverb . In fact most of my patches have 2 or 3 EQs assigned
It makes sense to me to have solo boost EQ before delay, particularly if it's a 1K hump rather than that boost, because I would always have that order when recording....
but it could also make sense to have it the other way around if you view the EQ as being the equivalent of the sound guy boosting the mixer channel a touch. No idea if there's a significant enough difference by the time you're gigging
I use EQ out front to reduce amplitude and shape the signal going into the amp - basically a preset, sculpted volume knob setting which can take an amp set to 80s Iron Maiden into ACDC and back along with a small boost in the loop to compensate if needed.. I also use EQ as a boost out front for heavier than early 80s Maiden. And I have an EQ in the loop as a boost or cut. And an EQ within my IR pedal for fine tuning stuff into FOH.
Did I mention that I like using EQ?
