What's your setup?
I'm about to go down the rabbit-hole of using two combos (for now, Peavey Classics 50 and 30) and as you know the possible combinations for setting them and the effects chain up are endless. I don't have all the bits yet so I'm trying to get a list together of good configurations to try out.
The C50 is 1990 so no effects loop but the C30 does have one - I'm not sure if I'll end up using it though as I like effects up the front. Otherwise I've kind of settled on this as a starting point:
Guitar>Dunlop Wah>Ibanez TS9>Ibanez Tuner
The tuner will be the splitter as it has a dry-thru.
Tuner Main Out>Carbon Copy Deluxe> Monty's MORE! (side A)> Classic 50
Tuner dry thru>Dunlop Volume pedal>BOO Tremolo> Monty's MORE! (side
![B) B)](/plugins/EmojiExtender/emoji/fb/16.gif)
> Classic 30
The Monty's MORE! is a dual clean boost.
I'll be running both amps on the dirt channels at edge-of-breakup, with the Classic 50 a hair cleaner. Both amps also have switches for channel and reverb.
I figure this way I can mute either amp using the Tuner or the volume pedal, I can have delay on one side and trem on the other, and loads of different gain-staging options. I can also run one reverb subtle and the other full-on so I can have either or both.
Is there something I'm overlooking? Those of you who have experience with this, what do you think I should expect and do you have any suggestions to improve?
https://www.andertons.co.uk/radial-engineering-bones-twin-city-buffered-aby-pedal-twincityaby
Compression, drives etc then a split via a Boss ES8
The dry then goes to output 2, Lehle p split for isolation and phase and then to the dry amp.
Wet then goes via modulation and time based fx to output 1 and then to the wet amp
My wet amp has an fx loop but to be honest, I prefer everything into the front end so I don’t bother with the 4 cable method.
A lot of kit to carry about but the sound is rather pleasingly pleasant
And to answer the op question. The 2 things to look out for are isolation (ground loop issues) and phases
Best to have a dedicated, buffered and isolated a/b/y if you're going to do it properly!
If just A/B between two sounds then it's much less of a big deal.
If you can make the two amp thing work in live situations then I salute and envy you!
Bandcamp
Spotify, Apple et al
I just run dual mono into an HRD and a 50w Marshall half stack, the latter dialled in for way more low frequencies than you'd usually use in a band mix. They're among our most fun gigs for me to be honest, I have almost total control over band dynamics.
Almost. An AC10C1 and a Marshall SV20C. That combination is sublime.
I had two identical SV20Cs at one point but it was nowhere near as good. The stereo effect was a bit neutered by both amps sounding identical. Much better to have two that complement each other.
Quick addendum: I recently came across a couple of posts saying you could "jump" the C50 mkI by inserting a dummy jack into the bright input with your guitar in the normal input, giving you the equivalent of the mid boost available on later models.
I tried this using a shorted 1/4" - phono adaptor, and what I seem to get is a treble cut.
Does that make sense? Am I doing it wrong?
It does not need to be engaged, so you can have two pedal lines with other modulation if you wish.
