Wiring Help.. Earth buzz..
Hi all,
Finally got around to rewiring my old '86 Hamer Chaparral this weekend after a recent refin.
Was a challenge given that I couldn't find an actual wiring diagram for this version but I thought I had enough to work with. Everything works but I get a pretty terrible earth buzz in any setting - even all pickups in the 'off' position. This reduces when I touch the strings/trem etc. Problem is that I've metered for continuity and everywhere I think I should see it, I do.
I've included some photos but just in case anything is unclear the setup is volume, tone (mid-range control actually), 3 off 3 way mini-toggles with neck and bridge offering phase reverse and neck offering coil split. I purchased replacement toggles. The only thing I wasn't 100% sure about were the earth wires from the pickups which I popped to ground.
Any help or advice really appreciated.
Si
  • Have you checked for continuity between your earth and the bridge? You need a wire from the earth to the base of bridge or posts depending on the configuration.
    Thanks for coming back.
    Yes - bridge (Floyd) is earthed back from trem claw and shows continuity.
  • SporkySporky Frets: 30210
    If the buzz reduces when you touch the strings then the wire to the bridge must be in place, and the noise is from a lack of shielding.
    When you touch the strings you are earthed through the guitar (and thus amp), and your body then acts as a shield.
    Thanks Sporky. Appreciate it.
    What I can't understand is that everything is as it was before (other than the fact I've rewired and replaced the old toggles) and it never buzzed before..
    Si
    That is odd.
    I don't think this fits the behaviour, but have you checked you've got the jack wired up the right way around?
  • Sporky said:
    That is odd.
    Thanks..
    I have; tip is live and shield to ground..
  • I would grab a length of wire and try grounding the backs of pots to the foil shield to see if that improves things. If it is an improvement solder that connection in place.
  • ICBMICBM Frets: 74497
    Check all the ground connections, especially to the cable shields - don’t rely on contact between the pot casings and the shielding plate. If that’s an unshielded cable to the jack, replace it with shielded.
  • Thanks all.
    @ICBM - is it actually better to insulate the pots from the shield plate and then wire to earth? Does such a thing as a ground loop cause issues? I'll replace the jack cable as it is un-shielded..
    Si
    No - there is no such thing as a ground loop within a guitar. Ground everything, don't worry about duplicating a connection.
    Brill - appreciate it..
    And I'll repeat my personal hobby horse - don't solder anything to the back of a pot. It's harder than having a central screw with a loop of solid core wire for the grounds, and there's a real risk of damaging the pot innards.
    Thanks - I'll give it a go!
    Si
