Hey
Recently I got an 85 Ibanez Roadstar II, which I’m really liking but I want to change a few things on it. Problem is, my electronics knowledge and skills are minimal at best!
Easy things first, it needs a new 5-way switch. It looks to be a simple Strat-style one, so I would expect that’s just a basic swap out for a new one.
The pots are a bit crackly, so while I’m in there I might swap those out too if they don’t clean up with some spray. The tone knob is push-push to coil-split the bridge humbucker, which I can’t understand the logic of when the push-pull is a visual indicator of the position! So I’d like to put a push-pull there instead.
Now there’s the more complicated stuff…
The bridge is meant to be a floating trem, which I’ve already blocked off with bits of wood because I know I don’t like that. The bridge is a “Pro RockR” - a massive chunk of metal that requires a screwdriver to remove and change strings, with little bits that can easily go missing. What are the chances of another, more modern and less complicated bridge fitting in there without much hassle?
Edit: I may be SOL on this one… https://www.thefretboard.co.uk/discussion/226345/ibanez-pro-rockr-trem-replacement It’s ok, I don’t hate the bridge, but it’s not my favourite thing in the world. This might be the thing stopping me treating this guitar as my main gigger, because emergency string changes in dark rooms would be practically impossible.
Next up should be fairly simple too, replacing the tuners with locking ones. Currently there are basic tuners but they’re not great because the stability would usually have been held by the locking nut, which I’m not using because I’m not using the trem. I might need to add a string tree to the headstock because it’s very flat and strings easily can pop out. Closer inspection reveals the previous owner has tried to cut the nut slots with his teeth apparently, might be better to just replace the nut entirely. Another thing to add to the list!
Like I said, these mods are probably easy enough for some of you to do with your eyes closed but I’d like to learn the skills myself!
I’ll put some pictures up soon of the detail shots, if required. I think everything here sounds doable, except maybe the bridge replacement
Thanks for any input and help, I need the tips because I’m totally blind here! I’m treating this as a warm up to a potential parts build I might attempt in future!
Cheers!
If the pots are original they will be quite decent quality. The logic of the push-push is that they're easier to use, but if you prefer a push-pull then it's a straightforward swap. When you take the old knob off, make sure the switch is in the 'up' position (there is a small visible difference) first, or you'll break the mechanism.
Zero.
They're absolutely incompatible with any other bridge, and this - combined with their tendency to break - is the most difficult problem with these guitars. The only really practical solution is to fill the original mounting holes and re-drill new ones for a standard Floyd Rose. I think there may be a small amount of body routing needed too.
The originals should be Gotohs I think, so some of their range with the same footprint should fit. You will need a string tree probably even if you fit staggered-height ones - but I would do that first and see if it works.
The Ibanez Pro Rock'r is a massive chunk of zinc.
Definitively this!
@HarrySeven and I can confirm this! Not even the earlier Hard Rocker is a direct replacement. (A small amount of wood would need to be removed. The cavity may not be entirely covered afterwards.)
With regard to the control electronics components, it would help to know the exact model number of the guitar. Failing that, post a photograph. Somebody here will recognise it.
HarrySeven And I … coming to a cinema near you this Autumn.
Forum feedback thread. | G&B interview #1 & #2 | https://www.instagram.com/_harry_seven_/
Some of the 5xx series had dual volume pots.
As mentioned by @ICBM, the original machineheads were Gotoh. Quality should be immaterial if the string lock device is present.
With both the Hard Rocker and Pro Rock'r vibratos, the smartest option is to set the base flush against the guitar body and treat it as a fixed bridge.
Once that is stabilised, it is time to look at the pickups. I treated my RS405 to DiMarzio Chopper, Cruiser N and Fast Track 1 pickups. It rocks but manages to retain a hint of Stratocaster in selector switch positions 2 and 4.
What's so baffling and frustrating about all these oddball vibratos - Ibanez are not the only culprit - is that the cost in the amount of time and effort designing and tooling up to manufacture them must have exceeded the payment of the licence fee to Floyd Rose.
I recently had a discussion about something at my current work where the designer of our lovely new product which is being released soon, has finally admitted it was a mistake to base it around a bespoke non-standard-size component, and they've changed it to a standard size. I did tell the designer that this was a huge improvement, for exactly the reasons we are now discussing... they have realised that if the bespoke part ever became unavailable, they would be in trouble.
Instagram
I’m similarly baffled by the choice Fender made in the early 80s with the Strat, to take the Freeflyte vibrato - not only the design and manufacture of a whole new and more complex bridge unit, but re-tooling (it would have been hard tooling, not CNC back then) for a totally different body rout - purely to save the manufacturing step of turning the body over and routing the back cavity. I’m amazed it would ever have been profitable, even if they’d made millions of them… but of course in the event, it was not at all well-received (now AKA the Freeshyte) and only lasted a year or so.
I wouldn’t even be surprised if it lost so much money it might have been a contributing factor to CBS selling Fender, so possibly a minor positive in the long run.
Unfortunately it's prohibitively expensive for anyone to tool up for making replacement components in steel - or even a better alloy - so your only option is woodwork to fit the next nearest decent bridge.
