Apple Watch Series 3 in 42mm size.
Comes with an official blue Apple sports band and charging cable (no plug)
This watch was a hand-me-down and the original owner was not particularly careful. As you can see from the pictures, I had to completely demolish the strap clip assembly on the watch and clean it out in order to get a strap to fit.
In order to remove the strap, you need a small screwdriver/pin etc to press the release latch on the strap itself.
The Control Centre button is also a little bit sticky; it doesn't always double-press quick enough.
Aside from that, the watch has the standard bumps and bruises from a time piece this age. I've been using it for over a year without any issues; functionally it operates totally fine and will still hold a charge for two days if you don't use it for sleep tracking.
https://flic.kr/s/aHBqjAXt12£40 inc P&P ono. All low ball offers considered!
