Steel strung acoustics with wide nuts?
I learned to play finger style on a nylon strung Yamaha electro-acoustic model. The nut was pretty wide, not as much as a full blown classical guitar but considerably wider than your average steel strung acoustc.
Songs that I can play comfortably on my Yamaha, I struggle with on my Walden acoustic steel string as the spacing is too close together for my old fat fingers when plucking away.
The classic Seagull cedar to S6 seems to be the obvious choice to solve this problem at it has possibly the widest nut at 1.8" that I've seen. Short of having a custom instrument built, I wonder what other acoustic guitars have nuts this wide or bigger?
I'd even thought of converting a 12 to a 6 string by removing every other  string as on my own model it is really comfortable to play finger style.
The only thing that puts me off the Seagull is that it's not a solid wood construction.
  • TanninTannin Frets: 5614
    I'm with you @equalsql ; - I much prefer a bit of space on the fretboard. 5 of my 8 guitars have a 44mm nut, which I can just barely tolerate, but  I much prefer 46mm or thereabouts. (My Guild, now given to my brother, had a 44.5mm not (1.75 inches in American measure) and even that extra half a millimetre made a very noticeable difference). My others are the Thunderhawk baritone and the new custom-made Mineur baritone (both 46mm - though the Mineuer feels noticeably wider because it has a deepish  C profile - and the custom-made Brook (45.5mm) which won't be completed until sometime next year.
    I will not tolerate anything less than 44mm - not even in the otherwise lovely 1980s Tiawanese Yamaha dreadnought  I could have bought for a song earlier this year but passed on because the nut was 43mm.
    Seagull make all-solid guitars,, including this one in spruce and mahogany with a 45.7mm nut
    https://seagullguitars.com/product/maritime-sws-natural-ae/
    Most European-made guitars have a 46mm nut as at least an option and very often standard. You can have any Lakewood you like with a 46mm nut - and Lakewood make really lovely instruments, quite reasonably priced for what they are, and screaming bargains if you can find one second-hand.
    * https://www.lakewood-guitars.com/guitars.php
    Dowina guitars are very reasonably priced and mostly come as standard with a 45mm nut, or they will hand-make one to your requirements for far less than you'd spend on, say, a Gibson or a Martin.
    * https://www.dowina.com/
    12-strings almost always have a 48mm or 50mm nut which is a bit much for most people. I tried my nice Cole Clark 12-string as a 6-string for a while (after I decided that fingerstyle 12-string was not a sound I liked) but despite starting on a 50mm classical and playing 12s (Eko and Yamaha) for most of my life, 50mm was just a little bit too much for me in the end,  Well, 50mm plus a shallow D profile I never quite got used to without pain in my not-so-young-anymore hands. 48mm I probably could have managed, and 48mm is quite common in 12s Just don't buy a 50mm 12 and expect to be happy playing it as a 6-string - my experience suggests that you'll struggle.
    Oh - one more thing. I gather that you have been mostly an electric player. For fingerstyle you may (or may not) find that string spacing at the bridge is the key.
  • The other thing that might help is if you can find a guitar with a fairly flat fretboard. My L'Arriveee is flatish and feels wider than it measures.
  • GTCGTC Frets: 267
    There's the Blueridge Parlour series (e.g. BR-341). All solid woods, 48mm nut, slotted headstock, well made - and, IMO, would give a Martin V a run for its money. Hobgoblin Music are a stockist. I've also come across some Washburns with a wide nut, but IMO nowhere near as good as Blureidge.
  • equalsqlequalsql Frets: 6225
    Thanks for all the great info @Tannin. I'm pretty well a 50/50 split playing between electric and acoustic.
  • KilgoreKilgore Frets: 8601
    Eastman have a number of models with 1.8 (1 13/16) nuts.
    E10 and E20 00 and P10 and P20 parlours. Bear in mind these are all small bodied 12 fret guitars and significantly more expensive than the Seagull.
  • BillDLBillDL Frets: 7648
    edited October 2023
    I find exactly the same thing with my Walden G630CE acoustic (43mm nut).  The strings down at the nut end feel cramped.  The slots in the nut bring the strings in slightly more from the fretboard edge than on my Sigma OM (1.75" - 44.45mm) that has the strings fractionally closer to the edge of the fretboard.  The combination of wider nut and string spacing on the Sigma makes all the difference.
  • MickeyjiMickeyji Frets: 108
    I have a Cort Luce 550LW, width at the nut is 48 mm. It's a really nice guitar for not very much money at all.
  • stickyfiddlestickyfiddle Frets: 27596
    My Bourgeois Mahogany D is a relatively wide (for a dread) 44mm
  • My Cort Parlour has a 45mm nut and I love the guitar. I hardly use a pick on it as I do on all my other guitars because there feels like so much more space on it. I don't even have particularly sausage like fingers either.
  • Gibson made a model in the 60’s called a Folksinger with a wide 2” nut. They’re great guitars
  • DavidRDavidR Frets: 777
    Maybe a bit contrarian but I've never gone a bundle on nut width. Either I like playing a guitar or I don't and I think I have a capacity to adapt. At least a little. Perhaps we all do? That being said, although I'm a 6 footer, I have always had largeish hands with thin fingers. My hand has thickenned up a little as I have aged but not too much. Probably if I had small hands with dumpy fingers it might be a bit different.
    Anyway, I have played all types of guitar apart from electrics throughout my life (now 67). I would prioritise tone, ease of playing and love for a particular instrument over any individual instrument characteristic which would just cause me to dismiss that instrument out of hand. I think I might have missed out on some good instruments if I had said, "Oooh, can't look at that, the nut width is too narrow".
    Also (!), nut width is not the only factor in finding a neck 'nice' or not.
    edited October 2023
    Just for fun measured nut widths on my present stable of instruments and they vary from 42mm to 52mm (classical obviously) with my 'go to' favourite being 45mm.
    I'm certain my 'go to' instrument is not my first choice solely on the grounds of nut width. It's just an all round comfortable instrument with a great tone and suits my playing.
    Thinking about it a bit more, playing my smallest instrument, I might have occasional poor note definition with a slightly greater incidence of difficulty holding down certain notes in certain positions in certain pieces. With subsequent dulling or buzziness of notes. But that wouldn't stop me playing it 'cos it sounds lovely.  :-)
    Interesting points @DavidR I don't agree overall, but I do agree in detail. My take is that different players are differently sensitised to different things. Nut width can certainly be one of them, but there are many others.
    I am very sensitive to nut width, only mildly sensitive to string spacing at the bridge, and really don't much care at all about the neck carve. (OK, very wide, ultra-shallow necks make my 60-something-year-old hand ache, but I don't dislike them, only have physical trouble with them.) But within reason, any neck carve is fine. I barely even notice.
    Now think about the next player, say one who cares a lot about string spacing at the bridge. (There are plenty of these.)
    The next player again is fussy about neck carves, and so on. We are all different and look for different things.
  • BahHumbugBahHumbug Frets: 350
    Taylor models ending with a 2 have fairly wide string spacing, I just measured the nut on my 712 and it’s 45mm-ish.  Someone once commented that it was like playing a classical, although his regular player had pretty narrow spacing.
    The problem with converting a 12 string is that they are engineered to handle the tension of, well, 12 strings, so probably would be quite stiff and unresponsive with 6.
  • Eastman E10 00 might be a good choice for you, or a second hand Recording King 12 fret model, I say second hand because they no longer make this model.
  • Dave_McDave_Mc Frets: 2389
    edited October 2023
    Agreed. Nut width tends to be something I notice- I'm not as bad as I used to be, but I still notice it. I've seen loads of other players who don't seem to care... and then I see loads of players (often the ones who don't care about nut width!) who seem to care a lot about scale length, and I don't really mind different scale lengths. Not saying I don't notice- I do- but I don't feel they make the thing much harder to play.
    Just because you're very picky about one thing doesn't necessarily mean you'll be equally picky about another. As you said, everyone seems to be different.
  • LittlejonnyLittlejonny Frets: 151
    edited October 2023
    Furch do all their guitars with 43, 45 and 48mm options. If you've got £1K to spend then I don't think you can do better than a Furch Blue. I played one in Richards and it was louder, deeper and more responsive than the Eastmans or Dovinas. They only reason I didn't buy one then and there was I played a Furch Yellow and that was even better.
    Then I had two cars fail their MOTs the following week, which has set me back somewhat, but the plan is to buy a Furch when funds allow. Anyway, I think a Furch Blue with 48mm nut would be killer.
  • Would a 48mm nut be a problem for those of us who play barre chords with smallish hands? Or is it still pretty miniscule in practical terms?
    48mm is pretty wide, @guitarjack66, but it isn't so much your fingers as your brain.
    It really does depend on what you learned on and what you are used to far more than it does on the size of your hands.
    If you started on (say) a Strat copy with a 42.5mm nut (common enough), 48mm feels huge and, depending on how long you played the narrow-not things for, you may never get used to it. Same story with those Japanese acoustics with tiny necks (Takamine, I'm looking at you.)
    If (like me) you started on a classical (50mm) and spent most of your life playing 12-strings (50mm and 48mm nuts) or bass (only 4 strings but set well apart) you'll find getting used to standard 44mm nuts very difficult. I'm still not really used to it despite owning half a dozen 44mm instruments these last four years, and playing them every day. I just collected my new baritone. It has a 46mm nut (nominal, it's probably more like 47mm in reality)  and it is sooooo nice after the 44mm squeezy things. Oddly enough, I'l a little put off by the wider RH string spacing but only a little and I dare say that will pass.
    Now look at someone playing a mandolin. Mandolin necks are bloody near microscopic! Tiny even for people with very, very small hands. But people get the hang of them (buggered if I know how) and play them well even with hands the size of soup plates.
    Anyway: main point, the size of your hands isn't the issue. It's how your brain is wired.
    Second point, I don't think barre chords will cause you any problems. You are more likely to discover issues playing intricate open-position fingerstyle stuff. ("Intricate" in this context meaning "tricky by your standards", however high or low those standards are.) Further up the neck (say 7th fret, just to name one) all necks are wider and nut width doesn't make much difference.
    Short answer: you'll be fine so far as the barre chords go, but watch out for the other stuff.
