https://www.instagram.com/insta.guitarstuff/
Si
When I first plugged in wasn't too impressed as it did sound a bit boxy and quiet, then found out I was running it in the wrong output mode and had to change that and couple of other settings. After that had a big jump in volume/clarity. Wasn't massively clear how to do this from the info online - a lot of change 'x' in menu 'y' followed by 20 minutes of trying to figure out how the hell you get to menu 'y' so every chance your friends one wasn't set up right.
The guy I borrowed it from had also been running it in the wrong mode which is easy done - just plug into the main output and you will get sound, but think that's just FRFR mode, not Kabinet mode. However, if you're getting sound out of it then easy to assume you're hooked up correctly and to not change the required settings. Once I had some joy with it he took it back and gigged it but thought it wasn't anywhere near as loud as his Tonemaster DR which was surprising.... maybe he'd not managed to set it up correctly again but, having not gigged it myself, can't really say. However, I can say that I'd definitely buy it off him if he was selling it as worked great as a 'home' amp at least and would probably cut it live... although not sure I'd go seek a new one out at full price.
On the power front, again using as designed with the Kemper, and setting the power boost (and watching the power meter) I've not faced a volume challenge for the gigs I do..
Si
