So in my recent question to find myself a better writing workflow, recording valve amps at low volume has cropped up. I've done it a few times in the past and was never entirely satisfied with the results. But EQ changes and microphone placement matter a lot.
For writing, this sort of thing is more than usable:
https://dl.dropboxusercontent.com/u/630473/GearDemos/Fryette Sig X/AutomaticWriting3.mp3It is a little fizzy to be sure, but this is recorded at a volume you can speak over. You can even hear the microphone picking up my channel switcher when I click them. This is a 100-watt valve amp, and for capturing ideas, it works really well at these volumes.
Remember, all you're doing this for is to capture riffs, and later on you can loop them, re learn them, and record them to a click.
Anyways... just a point I thought I'd raise.
Having recorded hundreds of different amps over a fair few years I have never found actual volume to be a deciding factor. When forced and necessitated to record quietly then noise floor is by far the bigger issue. That then also become tone dependent as we accept more noise in a driven tones than a clean one.
Amp are getting quieter and quieter with respect to noise floor and power points cleaner so I don't think recording volume is a significant issue anymore. I personally would always sooner select a louder/big amp running on one than any of the small home friendly amps.
Albeit a solid state amp, which makes it irrelevant to this thread .....
I think I'll go now .....
Feedback
