I'd try a change of V1 to start once you've settled in with the amp, I've got an unhealthy obsession with sylvania long plates so I've run those in amps for sometime, to me they give a smooth bite to the pre distortion, but each to their own, probably wouldn't bother with the marshall pres though.
Have you taken the chassis out yet? the quality of workmanship is awesome and the thickness of the chassis is bomb proof.
My YouTube Channel
That's some dedication too, you even had to sell your shirt to afford it.
Yeah I don't doubt it. I've never tried yours but (and this is about the 1000th time I've said this
-"By the way, @ecc83 - I just managed to find a decibel meter app which is calibrated pretty well up to a max of 100dB on my phone, and it was recording 99db up to the max with those settings, so I'd say it's probably between 99dB and 101dB at about 1m. Does that help?"
Lil bit. But I bet the app' has the A weighting and that will under read by about 20dB at 100Hz and we are also at the mercy of the sensitivity of the phone's mic and its response. The problem is that the "bright or dark" balance we hear this end depends hugely on absolute level. This assumes also of course on peeps listening on something 1/2 decent!
Dacve.
