I've done a full thread in the 'Making & Modding' section but thought that some folks who are players rather than builders may be also interested in the results.
It is a 17" scale nylon-string acoustic that I have designed and built for my two grandchildren to just pick up and make noise, or to learn to play if they have an interest, or to use as a cricket bat if they don't have an interest.
Yes - for as little as £75 you can buy a guilele/guitarlele - and I know they serve the same purpose and I am sure they are very good. However, I wanted to use this also to understand better what affects what when it comes to scaling down an acoustic guitar. My previous acoustic builds have included dreadnought steel strings, OM steel strings, an Irish Guitar Bouzouki...but never a nylon strung guitar and never anything smaller than OM.
So this post, is about the design features I tried and why, and the results and conclusions.
Here's the finished guitar:
![](https://i.imgur.com/U41Q85ul.jpg)
...and here's a better view of scale:
![](https://i.imgur.com/u4qAXTRl.jpg)
To the basic spec, it's:
- 17" scale, joined to body at 12th fret
- Sitka spruce top; mahogany back sides and neck; purpleheart fretboard; ebony binding
- through top pinned bridge; solid ebony pins
- Tenor ukulele shaped body; 3" (76mm) body depth
-- X-braced 25' radiused top
- Custom-braced 15' radius back
- Presently fitted with Savarez Corum Red/Blue strings (bass high tension; treble normal tension)
- Tuned 3 semitones higher than standard (G to G)
Sonically, my question was, 'can this scale and size be made that sounds more like a guitar than a ukulele?'
I won't go into the build details here (full build thread link below if anyone is interested) but will post some of the design thoughts and conclusions later in the post - and always happy to answer any questions anyone may have
![](/plugins/EmojiExtender/emoji/fb/1.gif)
So, crunch time - what does it sound like. Attached are some short clips of various styles recorded directly into my little Zoom H2n:
Stream Little Swift Soundfiles - Savarez Strings by Andy Rogers 5 | Listen online for free on SoundCloudThe build thread is here if anyone is interested in more detail:
https://thefretboard.co.uk/discussion/256191/a-little-acoustic-for-little-people/p1
