Feedback required...
digitalscreamdigitalscream Frets: 26586
edited November 2023 in Help & Feedback
Hi all -  been doing a bit of tweakery on a better dark mode, and I could do with a bit of feedback if anybody fancies being a beta tester.
If you'd like to head to your profile page and select "Night" from the dropdown at the bottom, you should see a very different tFB.
It's not perfect, but it's getting there...
NOTE: This is only for desktop browsers (or desktop mode), not the mobile layout. That's staying how it is, purely because mobile devices need as much contrast as they can get.
<space for hire>
  • I've tried it but can't see any difference so far?
  • Did you click "Save"?
    <space for hire>
  • GoFishGoFish Frets: 1411
    That is loads better (bye bye orange!).. I'm usually on faded and will probably return, but this is nice :)
    Yes and I got the 'changes have been saved' message.
  • DefaultMDefaultM Frets: 7326
    Doesn't do anything on my android mobile.
  • SporkySporky Frets: 28228
    It works for me, Android tablet running the Duck Duck Go browser.
    It looks fairly cohesive to me.
  • Ah, gotcha - this is only for desktop browsers!
    <space for hire>
    Ah that explains it! I'm on mobile.
    Interesting - I'm mot in desktop mode but it still works.
  • FelineGuitarsFelineGuitars Frets: 11594
    I quite like the Night mode , better than the other dark mode , which just felt a bit drab and grey
    Working fine in Safari and DuckDuckGo on Mac OS11.7.8
  • Cheers, guys. Take it for a test drive for a few days, see what you think.
    I've already identified a bit of an issue with the profile/notification/inbox menus - they seem to have some weird problem of appearing underneath some page elements (like the ads, which is annoying, but also profile icons. Absolutely no idea why.
    <space for hire>
  • Excellent, far easier to read Lee.
  • bertiebertie Frets: 13569
    turn the volume right up and stand close to and facing the amp
  • RolandRoland Frets: 8706
    Works on my iPad. It will take me a while to get used to it.
  • OK - just for a real beta, and I've no idea how this will be received...there's also "Night Wide" and "Night Full-Width" in there.
    Basically, the world's moved on a lot since the original design, and screens are a hell of a lot wider than they used to be. Have a play...you might like it, you might not. My personal feeling is that full-width is great on my laptop, but unusable on my 27" monitor. Wide, however, is a pretty decent compromise.
    <space for hire>
  • KittyfriskKittyfrisk Frets: 18773
    'Night' works fine with Safari and DuckDuckGo on Mac OS 10.4.6
    Previously being using Faded, might give this a go. Good
    effort 1
    Edit: back to Faded. Found the Night theme looks much cooler, but needed more concentration as all the screen information was '
    flatter' & harder to separate content from background. I'll try again though as I like the look.
  • HootsmonHootsmon Frets: 15962
    Pretty good and I will keep.....easy on the peepers just like the USA forum....way tae go Digi
    tae be or not tae be
    Strangely Night mode displays Comments, but not Discussions:
  • blobbblobb Frets: 2953
    Yes, works for me and looks good. The yellow 'New' box is a bit sharp though, the white text is a bit washed out as a result.
    Feelin' Reelin' & Squeelin'
  • Phil_CPhil_C Frets: 252
    I really like it. I use dark modes for almost everything
