i have used it with logic but performance took a massive hit (I’m running a 2015 MacBook Pro so that may be why)
also, I used an Aston origin for the room measurement so probably not ideal , but the whole experience has been very interesting and I always have it switched on now :-)
I use an alternative solution that is way better, has loads more capability/flexibility but is way more complicated to configure..
Everybody is different however and if you dig the result then that's great..
At £40 I presume you've bought the headphone version? If so it will be fine..
The solution I use is for for speaker/room correction and it's called Accurate. Supports linear and min phase convolution and the results are amazing (depending on what you're starting with in terms of acoustics). I run a 2 + 2 setup. The cost is very reasonable for what it is capable of (far more than just my application) however the learning curve is a little steep as it's not the most user-friendly application. Once you've grasped it, it is brill.
Si
Acourate..
https://www.audiovero.de/en/acourate.php
Si
