I'm doing a lot more recording these days so my Marshall stack and high wattage amps aren't doing it for me. Space is a factor as well as weight, I'd be more keen to gig with them if they were lighter.
My main question would be whether I should opt for a selection of 5w amps or amps in the 15-20w range that I could still potentially gig with.
Ideally I'm looking at the big four tones to satisfy most guitar amp needs.
Vox AC30
Marshall JTM/Plexi
Fender Blackface
Mesa Mark Series
In the 5w range I could opt for:
Vox AC4 Handwired
Marshall Class 5/JTM 1C
Fender SF Champ (had one I shouldn't have sold)
Mesa... (Currently have an MKI but not sure I could get those tones in a smaller package, Studio Preamp or TriAxis maybe.)
15w+ Range could be something like:
Vox AC15
Fender Princeton Reverb
Marshall (not sure here, maybe 1974x)
Mesa TA-30
Part of me just wants to get the TA-30 as that covers most of the tones to some degree but I'm too much of a gear maniac to have just one amp... (I'm not against the MKV but I prefer the simplicity of small single channel amps)
What do you lot recommend? The 15w+ route is a lot more expensive but I'd be selling my current amps to fund them. 5w amps would be fun to crank up, easy to move around/place in different rooms and work with extension cabs if needed.
I was gonna keep a select amp just for gigging though. Still haven't decided what that would be!
Doesn't the Line 6 DT25 cover most of those sounds? That could be a winner for you.
Very few of the amps under 25w that I have owned sound anywhere near as good as the classic famous designs from 25-50w.
if 50 years of amp development had been centred on producing 5w amps, this might be a different story, but as it is, the best sounds so far discovered are mostly only possible on these designs, and they can't just be scaled down to 5w
As ICBM says, none of the little amps that are named as a little brother to a classic actually sound like the one they allude to. the AC15 is close, but still amazingly loud and heavy
The only options I would recommend are:
Thanks so much for all the suggestions. I think I'm with ToneControl on this one. My third option was to invest in a Riviera Silent Sister/Mesa Cab Clone and get a selection of higher wattage heads. I know Fender have recently released a Deluxe Reverb Head (although a Dual Showman would be great.) Vox do heads (I think) and I already have a Marshall VM head and Mesa Mark I.
I'm not completely deluded in thinking 5w amps are going to cover the same sonic territory as their larger brethren but if they're not really in the ballpark I might as well keep my current amp heads and add to my collection.
I'm not saying that smaller amps are not good. But they wont give you the same feel as a bigger amp. Not even ballpark. If they did, I would've stuck with the Orange Dual Terror and not gone back to larger amps.
If it's volume you're fighting, get an attenuator or an ISO cab.
ISO cab with full-power amps or amp modelling were the only solutions I have that work (although now I live in a house with thicker walls, and I added secondary glazing to the windows in my loud room, so no one outside can really hear even my 100w amps
I think investing in larger amps means I can always gig with them if I need to. Granted I'm mainly using them for recording so the Mesa TA-30 is seemingly like a very value oriented option.
I guess as it stands now I would only need a Deluxe Reverb and AC15/30 to round out my amp desires. Hmmmm. Lots of saving to do I think.
The Andertons demo of the CabClone was pulled by Mesa as their unit was defective (according to them and didn't sound as good as it should have). I'll wait till they do another demo but for 200 bones it's worth a punt for silent practice and getting a signal to my computer to use with impulses. ISO can can be used when re-amping. Just thinking about it all sounds exciting. Such a geek hah.
I have the original without the EQ and from a personal perspective (and as a previous MKV owner) prefer the non-EQ version as it makes the amp so easy to dial in its unreal, you'd have to work pretty hard to get a bad sound out of it. However if you want to get closer to the classic tones you mentioned and don't mind the extra faff when dialing it in the later EQ version is the way to go.
I haven't tried the Rivera - This review: http://www.premierguitar.com/articles/Rivera_Silent_Sister_Isolation_Cabinet_Review
says it reduces the external volume by about 30dB. That's not quiet enough to hear the mix while you record
The Hermit cab has 2 layers, and is made to be quiet
The custom made one I have is much quieter, with a 30w or 50w amp played into it, all you can hear in the room are the strings, and the output transformer if there are a few loose windings
http://s809.photobucket.com/user/toneuk/library/Oak Iso cab
Made of oak outer case, hemp insulation, then an inner box of MDF, we experimented with minimal baffles: in teh end the ones that are simply a square of wood worked best: the mic is so close, there is no bass loss liek you would hear a few feet away, and more chance to get movement of air in the ISO box, and 3 drivers can be fitted at once, each with its own microphone
I can advise that when recording, it is much easier to play and record without a random 80dB coming out of a poor ISO cab in the same room
To Anyone who wants an Iso cab, I would sell mine now - I have secondary glazing and Pro amp sims, so don't need Iso boxes anymore
personally I think this is much better made and functional than any commercial offering
this one is less boxy sounding than the commercial ones, they have very little volume compared to this
Sound was never "boxy" to me, but I guess better quality acoustic foam might be good
Since there is no grill, you can mic up even closer into the cone
I found that all I needed was a bit of EQ and a multi band compressor to get a really good sound
