traded Musicman Majesty BFR Petrucci KOA Limited edition 2017
Looking potentially to swap my 2017 Musicman Majesty BFR Petrucci KOA Limited edition 2017. Comes with two back plate (one signed by the man himself). Cold weather may change my mind.<br>Only looking to trade for other high end guitar (but no heavy guitar please). Trave value GBP4000. I'm based in London<br><p>The Music Man John Petrucci Signature Majesty Ball Family
Reserve (BFR) is an immaculate example of Petrucci's design demands and Music
Man's expert art and craftsmanship. You'll enjoy near-endless sustain from the
mahogany neck-through construction, while the koa inset top adds a touch of
attack. Every possible tone you need is onboard — accessed through the guitar's
DiMarzio Sonic Ecstasy humbucking pickups, piezo-equipped tremolo, and onboard
active boost. Petrucci already considered the Majesty to be his finest model.
With the Majesty BFR, Music Man just made it even better.</p>
<p><b> Limited-edition construction</b></p>
<p>This BFR sticks close to the glory of the Majesty solid body
electric guitar while adding exotic touches that make it unlike any JP
signature model before it. The eye-catching design offers you a mahogany
neck-through construction with a beautiful koa top, angled headstock for
sustain, and a beautiful gloss-on-the-front, satin-on-the-back finish. Every
bit as gorgeous looking as it is playing, the Majesty BFR is, as far as John's
concerned, the best Petrucci you can get. And he backs it up by hand-signing
each one.</p>
<p><b>A custom JP/MM piezo floating tremolo</b></p>
<p>John Petrucci can do it all and needs a guitar that can
too. Designed in conjunction with JP and Ernie Ball Music Man, the proprietary
piezo floating tremolo system gives you freedom of expression you have to
experience. You can rest easy knowing your tuning's stable with the Schaller
locking tuners, ensuring your trem returns to perfect position every time. And
who can forget the piezo system giving you amazing full-bodied acoustic tones
on demand? The Majesty BFR offers more tones and control than just about any
guitar we've ever seen at Sweetwater.</p>
<p><b>Onboard 20dB gain boost and a passive
coil tap</b></p>
<p>One of the defining features of all John Petrucci signature
guitars is the forward-thinking and immaculate-sounding electronics. Recently
JP has gone to an active preamp system in his guitars, offering you push-push
control over a 20dB gain boost and over a passive coil tap when in the dual
pickup position. Need to push your amp over the edge for a screaming solo? Just
tap the volume control for a huge output jump! Want that single-coil sound for
your clean passages? That one resides in your tone control. Nothing is holding
you back from all the tones in your head.</p>
<p><b>Ernie Ball Music Man John Petrucci
Majesty Ball Family Reserve Features:</b></p>
<ul>
<li>An exotic take on JP's signature
Majesty</li>
<li>Koa top imparts the instrument
with a warm and inviting look</li>
<li>Mahogany neck-through
construction gives you added sustain</li>
<li>Gloss top and satin back look
stunning and feel even better</li>
<li>DiMarzio Sonic Ecstasy pickups
will get you that much closer to JP's sound</li>
<li>Built-in active preamp adding a
gain boost and coil tap to your sonic arsenal</li>
<li>Custom JP piezo floating tremolo
system for total control and a variety of tones</li>
<li>Schaller locking tuners to
strengthen your tuning stability</li>
<li>Hand-signed</li>
</ul><a rel="nofollow" target="_blank"><img width="640" alt="" src="//img.youtube.com/vi/_aYf7wMWXwg/0.jpg" height="385"></a><br><br><a rel="nofollow" target="_blank" href="
https://imgur.com/a/pH7HuPb">
https://imgur.com/a/pH7HuPb</a><br><br>
