traded Musicman Majesty BFR Petrucci KOA Limited edition 2017
bddbukbddbuk Frets: 35
edited April 28 in Guitars £
Looking potentially to swap my 2017 Musicman Majesty BFR Petrucci KOA Limited edition 2017. Comes with two back plate (one signed by the man himself). Cold weather may change my mind.
Only looking to trade for other high end guitar (but no heavy guitar please). Trave value GBP4000. I'm based in London
The Music Man John Petrucci Signature Majesty Ball Family Reserve (BFR) is an immaculate example of Petrucci's design demands and Music Man's expert art and craftsmanship. You'll enjoy near-endless sustain from the mahogany neck-through construction, while the koa inset top adds a touch of attack. Every possible tone you need is onboard — accessed through the guitar's DiMarzio Sonic Ecstasy humbucking pickups, piezo-equipped tremolo, and onboard active boost. Petrucci already considered the Majesty to be his finest model. With the Majesty BFR, Music Man just made it even better.
 Limited-edition construction
This BFR sticks close to the glory of the Majesty solid body electric guitar while adding exotic touches that make it unlike any JP signature model before it. The eye-catching design offers you a mahogany neck-through construction with a beautiful koa top, angled headstock for sustain, and a beautiful gloss-on-the-front, satin-on-the-back finish. Every bit as gorgeous looking as it is playing, the Majesty BFR is, as far as John's concerned, the best Petrucci you can get. And he backs it up by hand-signing each one.
A custom JP/MM piezo floating tremolo
John Petrucci can do it all and needs a guitar that can too. Designed in conjunction with JP and Ernie Ball Music Man, the proprietary piezo floating tremolo system gives you freedom of expression you have to experience. You can rest easy knowing your tuning's stable with the Schaller locking tuners, ensuring your trem returns to perfect position every time. And who can forget the piezo system giving you amazing full-bodied acoustic tones on demand? The Majesty BFR offers more tones and control than just about any guitar we've ever seen at Sweetwater.
Onboard 20dB gain boost and a passive coil tap
One of the defining features of all John Petrucci signature guitars is the forward-thinking and immaculate-sounding electronics. Recently JP has gone to an active preamp system in his guitars, offering you push-push control over a 20dB gain boost and over a passive coil tap when in the dual pickup position. Need to push your amp over the edge for a screaming solo? Just tap the volume control for a huge output jump! Want that single-coil sound for your clean passages? That one resides in your tone control. Nothing is holding you back from all the tones in your head.
Ernie Ball Music Man John Petrucci Majesty Ball Family Reserve Features:
  • An exotic take on JP's signature Majesty
  • Koa top imparts the instrument with a warm and inviting look
  • Mahogany neck-through construction gives you added sustain
  • Gloss top and satin back look stunning and feel even better
  • DiMarzio Sonic Ecstasy pickups will get you that much closer to JP's sound
  • Built-in active preamp adding a gain boost and coil tap to your sonic arsenal
  • Custom JP piezo floating tremolo system for total control and a variety of tones
  • Schaller locking tuners to strengthen your tuning stability
  • Hand-signed
https://imgur.com/a/pH7HuPb
