I am thinking of going for a Hiwatt Custom 50 SA212. Has anyone tried one of these?
I am expecting it to be super heavy and super clean. Is there any forum wisdom?
I am looking at combos as I am really not a fan of stacks but open to opinions and information that might convince me that the stack is the only way to go etc
@Gassage I am sure you can give me some info
The Bigsby was the first successful design of what is now called a
whammy bar or tremolo arm, although vibrato is the technically correct
term for the musical effect it produces. In standard usage, tremolo is a
rapid fluctuation of the volume of a note, while vibrato is a
fluctuation in pitch. The origin of this nonstandard usage of the term
by electric guitarists is attributed to Leo Fender, who also used the
term “vibrato” to refer to what is really a tremolo effect.
He also uses about 40 other amps.
In fairness he'd sound more like him with a shoebox and an elastic band than all of us on here put together.
As it happens, there was a big debate on the Gilmour forum about this - everyone agrees, no-one can explain why.
I know when he plays small venues he uses a Tweed Twin and SA212 together, sometimes 2 of them.
But I guess it all depends on how you run your HiWatt - as a pedal platform, either will be fantastic, IMHO.
Just my opinion, though... :-)
Not in this case. You need just to read up on the sad history of Hiwatt, how Music Ground bought the brand and then prosittuted it, how they released unauthorised sig models, how they sent production hither and thither. The MG ones are not so bad actually, especially the early ones, but they are not quite the same, mainly due to the transformer specs.
However, you are very clear about what you want, so responding to that:
1. Yes, the SA212 will do what you want, MG or whatever.
2. You'll pay the same for vintage or MG.
3. Vintage DR103 and Cab will cost a similar price to an MG SA212 (so will a vintage SA212)
4. I talked to a couple of people about the combo v head. The wisdom was that the Head and Cab are more chimey and the combo has slightly more sag.
5. You could get a silverface Twin Reverb that'll get you very very close to the Hiwatt tones for half the price, if you're not badge worried.
6. I've emailed a couple of my friends who deal/trade older Hiwatts.
7. Combo's much harder to find that heads.
8. Hiwatt original cabs even harder to find and can be silly money, but a Celestion G12 75w will be dandy.
9. Still, search around and you'll get a cab for £450.
10. If you see a Reeves amp, that's the best modern alternative, all built by the late Dave Reeves, ex Hiwatt.
Genuine question, a boutiquey kind of clone would be ideal - new amp, warranty, sounds similar (the same... It's a clone) and super tidy wiring (maybe not quite as anal, mind). Expensive, perhaps, but it means you don't line music ground pockets.
