Bandcamp
Spotify, Apple et al
Yes it is an oversimplification, but like a lot of these things it's very useful.
If it wasn't true, speakers would all sound the same at low volume, and they don't at all.
It also disposes of the myth that you need to "push" speakers to get "breakup" or make them sound good. You don't - with a few exceptions, all of which I can think of that have fairly stiff edge surrounds and need a little bit more power to make them move freely... the V30 being a good example.
If anything, pushing the speakers too hard so the breakup becomes chaotic doesn't actually sound good - or at best, sounds like Neil Young. (Which I am well aware is the same thing to a lot of people .)
And agreed.
I don't even mind the V30 at low volumes, at least for certain things. That's true ("certain things") for most , if not all, speakers, though. But it may also be true that they don't sound quite as good as some other speakers at really low volumes.
A guitar speaker has a magnet, basket, voice coil and cone just the same as a "hi fi" woofer but there the similarity ends.
Even my dinky Tannoy 5A cones have a pk-pk displacement of around 8mm. A Super 65 (G12N-65) I happen to have handy has barely half that and is far stiffer. Bottom line: Guitar speakers do not work as "pistons" to hardly any degree at all and are really just a vibrating membrane.
That you don't need to drive the bllx off a speaker for good sound was brought home to me when Son and I were playing around with a 15W Dominator clone and he got the best ZZ Top "grind" at a measured 90dBC SPL at a mtr from a Greenback. That is well under a watt!
Dave.
