But when it worked properly, he was very happy with his sound.
Built in XLR balanced outs (as well as non-balanced outs)
MIDI
Groundlift
Staggered footswitches - such a simple solution to make switching much easier
Dedicated amp controls - (this was a feature I really liked in the Zoom G11)
Dedicated buttons to access each section quickly (modulation, reverb, delay etc) (a feature I really liked in the Mooer GE300)
Globally accessible looper
Built in drum machine (basic, but still a nice extra to jam to & drums can be looped too)
Initial & wait modes for footswitches - brilliant for teeing up something whilst you're playing
Cab off setting (global)
Patch level meter
180 sec looper
Customizable Display Mode (3 modes)
Magnify the patch names and numbers (great option for gigging).
1000mA (a sensible power requirement, unlike the Pod Go)
All metal construction
Re DSP usage the manual refers to using up to 11 effect modules simultaneously - I think you can still hit DSP limits though as the manual says "In some extreme cases the signal processor may become overloaded and display a “System Overload” message. Please try other effect combos instead". Unlike eg Pod Go you can only have one effect from each 'type' so if you wanted eg two delays or two modulations this isn't an available option.
For info, Hotone, Valeton, Sonicake are all the same company, Valeton is merely a registered Hotone trademark (as is Ampero). But for under £300 (and there's a red one being offered brand new by Sonicake for £262.99) this is an absolutely stonking unit, clearly targeting the Line 6 Pod Go. If I was buying an MFX today, assuming this still sounded good, I'd seriously consider this for for my gigging needs because it addresses quite a number of things that have deterred me from using my Pod Go as a main gigging MFX.
Firmware updates seem to be regular with real enhancements (rather than just bug fixes). The GP200 seems to have had a new update every 6mths or so, and is currently on v1.40.
Some reservations though:
Line 6 customer support is perhaps arguably the best out there currently - I don't know what Sonicake's support in the UK is like
I haven't seen/tried the unit, so apart from vids I don't know how it feels and sounds tonally especially as compared to Pod Go following the v2.0 upgrade with new cab engine & IR's.
Build quality appears good, but not sure about reliability or if any major glitches/issues.
The limitation of only one effect per module (and similar to Pod Go its single routing only) might be restrictive for some users, but largely that's how I use my MFX anyway and you can always add a favourite pedal or two in the fx loop.
I'd be very interested in trying one of these and sharing feedback comparing to my Pod Go but no store near me has one to try. I'd love to find a modern simple to use mfx that sounds great, was reliable, easy to use/tweak, gig worthy & could supercede my old Tonelabs.
Just seen a special offer posted by @Rich31k ;;;;
https://www.thefretboard.co.uk/discussion/259080/psa-valeton-gp200-for-216-75-and-gp200lt-for-178-83#latest
If I didn't have a Pod Go I'd snap this up but without trying one out and living with it for a while to know if its good enough for my gigging needs, it's still a fair amount to take a flyer on - I bought Pod Go to 'replace' my Tonelabs for gigging, but that didn't really work out as well as I hoped. The problem is that until you've lived with a MFX for a while it's very difficult to know if it's going to meet your needs. Finding an MFX to fit live gigging needs is a very different perspective to those buying something that they will simply be playing at home or jamming with friends or using to record.
HOWEVER having read the manuals and watched the videos I think it has a major problem for gigging. Although you can customise footswitches A B C D per patch to switch on/off pedals in stomp mode, the display only shows ABCD - so if you have a dozen patches for a gig there is no way you can remember which footswitch does what in each patch. Unless there's a way to name these switches per patch this important stomp feature is useless for a gigging player. Unless I'm missing something?
(Pod Go had a similar issue with its snapshots and it took Line 6 18 mths before it was upgraded with the ability to name & colour code footswitches)
I hope I'm wrong & I've emailed Valeton/Sonicake for clarification. If anyone here has bought one please let me know if I'm right?
