The signs of trouble from running into too high impedance would likely be blown valves when the amp is cranked - you may not get any other warning. If you're not cranking it there's no risk really, it just may not sound quite as good.
When something does eventually go wrong it is a pig to work on because of the way the circuit boards are arranged, and will probably cost a lot to fix.
I've had combos with 6L6s that have lasted for years (Hot Rod Deluxe, Lazy J 20). I'd imagine that the amount of vibration would be similar so I think it is more to do with the EL84s and the voltage they are run at. The HRD and the Lazy J are relatively low plate voltages compared with some 6L6 amps so they are probably not being stressed by the voltage but fundamentally I think it is a more robust valve than the EL84. You only need 2 6L6s instead of 4 EL84s so they tend to work out cheaper even though the individual valves are more expensive.
I've not got a lot of experience with other EL84 based amps so I don't know how the Peavey compares to them for valve life. They would probably be somewhere in between. @ICBM could probably tell you more on that.
