All the patches are just amp blocks, except the Recto 2 Red Modern which is boosted with a TS808 (pretty standard settings, low drive, high level, tone just about 12 IIRC). On all the amps I used the following LF settings - freq 114.2 hz, amount 5.79, and Q of 3.150.
After that all the amps have zero advanced tweaks. I've just adjusted Gain, Bass, Mid, Treble, Presence, Depth (Resonance), and Master Volume, which I consider to be standard controls as per a 'real' amp. I don't find it takes me long to get a tone I like through my cab now that I've got some LF settings I like.
I didn't use the i5 at all, the 57 came out better to me every time IMO.
By and large I'm not feeling the mid-gain clips. They seem too dark to me, but maybe that is what you're going for. They sound like amps... but I don't think they sound as good as a cranked valve amp. There is something lacking that I'm struggling to put a finger on. Heft... weight... something lacking that isn't quite related to frequency. You can hear it in the Dirty Shirley clip, around 0:15... the palm mute there doesn't jump out at you like a real amp does. It's too flat, fuzzy, and lacks bite.
The AFD clip is lacking lowend for me. The tone is nice, but isn't quite where I would personally want it. The 6505 SM57 clip is closer for me.
Recto 1 red has way too much flubbiness on the lowend for my tastes. I found that quite difficult to clean up myself when dialing in that amp as well though. I think it's just what recto's do.
I think of the high-gains, the 5153 red is my favourite. But it's also lacking a bit of punch.
I think overall... there seems to be a lack of punch. It could be the Axe or the Matrix, or it could be microphone positioning. Hard to tell really.
