So in the New Year I will be upgrading the electronics of two Japanese guitars. One is a 2014 Tokai Les Paul Special, the other is a 1980 Navigator SA120 (ES335 style - so no backplate to take off and look through).
I would ideally like to buy pre-wired looms from somewhere like Axes R Us. This means though that I need to get the spec right - and the Imperial or Metric specification is something I don't know how to answer, although I have heard people say that Japanese guitars are often metric.
How do I find out whether the electronics on these two guitars are metric or imperial?
And is there any need to make a distinction between metric & imperial for pickup replacements?
Thanks in advance
Metric replacement components will fit Metric drilled holes neatly. They would also fit Imperial holes albeit somewhat loosely.
Imperial replacement components might fit sloppily-drilled Metric holes. Be prepared to enlarge holes using a reamer:
Interesting to see what pickups you put in Navi SA as I'm on the fence about whether I like hot (currently) or not so hot pickups in my Navi SA.
flanging_fed “
You might be able to measure the shaft diameter of the pickup selector without removing anything.
If you want to change the pickups and you can bring yourself to do the 335 the ‘cheat’ way by cutting the pickup cables in the cavities, that will save a vast amount of work.
Just out of interest, is the "cheat" way just cutting the cables fairly close to the pickups, so you can get at them through the pickup cavities, and then connecting the new pickups' hot and ground wires to the hot and grounds of the old pickups' cables?
If you want to make it less of a bodge - and if there's room in the cavities - you could add some proper terminal strip screwed to the cavity floor to make the connections - but it really makes no practical difference, unless you're going to be changing the pickups a lot.
https://uniqueguitar.blogspot.com/2018/08/guyatone-guitars.html
Sorry, historical thread hijack .
Had a look inside my Tokai LPS and that's using Alpha pots on the volume (value unclear), and 500K 'GF' pots on the tone (think these are Goldo brand, from having a read around). In any case, I'm happy enough with them, they can stay in place and I will just need to replace the (broken switch).
On the Navigator 335, I'm less clear, obviously because its not easy for me to open up. I might have a play around. But I'm a little sceptical of the whole electronics purely because, over time, I've become less happy with the pickups. They are quite hot and, much like @Neilybob , I'm thinking to swap them for something lower output, more chimey and classic.
Rolson 60515 Two LED Telescopic Inspection Mirror,42 x 65mm : Amazon.co.uk: Automotive
