I've been using the same browser for ages (Safari) but in the last few weeks I've been having issues with the editor.
Very often I'll start a new line and will be typing away but the text will only appear after I've hit the first space of the sentence.
Other times I can type no text at all unless I return to a point in the post I'm typing between paragraphs I've already typed. Then I can type what I want but will have to cut and paste to the end where I wanted it to be.
Other times it behaves perfectly normal. Can't quite get my head around it. I think it happens most often when replying to a post rather than when creating a new topic - this post, for instance, has behaved perfectly while I've been wittering away.
Not a major issue at all, just wondered if anyone else had noticed it or if it's something I've turned on/off by mistake or whether maybe a software update to Mac OS has done something to Safari?
TIA
Turns out there is an H in Haych! ~ Sporky
Bit of trading feedback here.
If you get in a proper pickle, you could click the right-most editor button: 'Toggle HTML View' and fix it up manually (provided you know what you're looking at ).
