So, got the itch to get a JVM...don't want the hassle of a head/cab so combo it is.
Seen a 410C locally, am I best shying away from them for any reason or are they generally regarded as decent amps.
I know the combo weighs the same as a Toyota Yaris but surely it can't be as a bad as my previous MKIV Mesa Hardwood Combo? - handles on the side and stuff I assume?
Will be used sparingly for gigs (we are generally a FOH/IEM band) being controlled by FM9's Midi - which hopefully will work OK - just feel a little bit exposed not having a proper amp on hand (if that makes sense)and will sometimes be nice to have an amp behind me..
It ended up getting displaced by a DSL40CR for the following reasons:
-weight, as you can imagine. Not actually too bad when using the side handles on level ground, but absolutely brutal to get up and down our narrow, steep stairs.
-no external bias adjustment! Combined with weight, that made taking it to a tech a massive hassle as well as an expense, even if the EL34’s only need replacing every couple of years. Going through that once was more than enough, and I wasn’t about to open the chassis with the amp powered up. DSL has external bias points.
-I actually preferred the DSL voicing on the corresponding crunch and OD1 channels! The JVM edges it for high gain stuff certainly but I mostly play classic rock, or early 90’s Megadeth etc at a push. I should say that this is after I swapped the DSL stock speaker for a G12H Creamback.
-JVM seemed to have noticeably higher circuit noise especially using the FX loop - presumably because it’s got lots more gain… I ended up programming in 2 separate noise gates on the multi fx. DSL much quieter.
Good point on bias being easy on DSL too… advantage of Mesa Boogie for theatre and busy gig work is straight swaps with Mesa matched tubes.
Even better, you get a trim pot for each valve. If they’re tired and out of whack, or you’ve been sold some that are mis-matched, you can tweak them individually.
Soz, I appreciate that’s not helping your bank balance
Agreed
LOL Thanks
OD1 is obviously where it’s all at but I’m also really liking OD2. Can’t get Crunch settled yet though, Red Mode is where I seem to be settling with Crunch channel as my AC/DC type crunch but need to spend more time with it I think.
Midi works a treat too with the FM9
