Hi all you clever techies. A facebook friend has a Vox Valvetronix AD120VT combo that has two stock 'Vox own' Celestion Seventy Eighty speakers, rated at 97dB. He's just got himself a Vox V412BL extn cab that has 4 x 30w 16 Ohm GSH12-30 Wharfedale speakers (rated at 95dB I believe) - 16 ohm wired in parallel pairs to give Left and Right separate inputs of 8 ohms rated at 60 watts per side.
When running the extn cab together with the on-board Celestions, he said the Celestions are completely over-powering and drowning out the 4x12, so he's done a mod that lets him bypass the internal speakers so that he can enjoy the 4x12. He's put in a pair of breakout banana plug female connectors to access the amp outputs and put banana plugs on the internal speaker tails - so they remain plugged in and work as normal -
but can be switched out by merely plugging other speakers in as required
Now, I appreciate that there's a 2dB sensitivity difference but nevertheless with 4 speakers pushing more air I'm still a little surprised that the 4x12 extn cab is being so overpowered.
Does this seem right to you guys?
If the 4x12" is closed-back it probably won't sound as loud in the room as the open-back combo either.
That does mean that the individual speakers in the extension cab are each receiving half the power that the ones in the combo are, but that should still mean that overall, the 4x12” has about a 1-2dB advantage since there are double the number.
So I think the difference is down to speaker sensitivity, voicing (a more middy speaker sounds louder), and the cabinet type.
https://youtu.be/QHZ48AE3TOI?si=Nkkew93hA8WO4stK
