I use this amp for my rock/metal band and use the green channel as clean and the red channel as my main rhythm / distortion sound. This is basically the best way to run it if you want a dedicated clean tone.
Here's an old video of my band demonstrating:
contactemea@fender.com
i just don't get all the moaning about the volume jump if you want three separate channels they do one its called the 100 watt. its double the price of a 50. no company is going to make something with the same feature set as their top of the line model at half the price its just not good business sense.
essentially you get evh sound cheaper just with two channels which you can choose to have a clean or crunch.
They are great sounding amps a less them a grand new you show me a three channel amp that can do what the evh can do at less than a grand new i don't think you will find one.
the only real way i found to make the volume jump more manageable was to use an mxr line driver in the front and it gives you a decent clean and boosts blue channel a touch so no big jump that way.
I'm not sure what tonal difference that makes, but functionally it would be easier if it did.
