The CS336 has particularly small f-holes but it does have a nice big cut-out in the bottom of the bridge pickup cavity, so that was the route I took.
And just to reiterate - never again!
https://sixstringsupplies.co.uk/
Our YouTube Channel for handy "How-To" Wiring Tutorials
The neck pickup on my 339 kept cutting out, and when I fished the loom out, it turned out that the Gibson custom shop hadn't actually soldered the pickup's hot wire. Total faff to get it all back in.
In most cases I'm like BillDL in that I've given up using thread - I've never used tubing - since it tends to make things more complicated than without, in my experience. I do have a purpose-made jack puller (a filed-down plug that will pass through the hole in the body, with a long length of stiff wire attached to it) but normally I do the rest with fingers through the f-holes and tools to grab the ends of the pot shafts when they're below the holes. If the loom is made fairly rigidly in the right shape first, then everything tends to line up OK once it's inside - if the wiring isn't the braided stuff that can be soldered, I use cable ties.
*I have no axe to grind for PIO caps!
(Those PIO caps would actually fit on the backs of the pots, in fact.)
