You can create musical tension with any element of the music - volume, complexity, rhythm, melody, harmonics, or just by simply doing something completely unexpected - so long as what you do makes the listener harbour the expectation of a resolution as the tune drives forward and it makes them think, 'where is this going?'. If people think that as they listen, then it is job done as far as creating tension goes.
Probably the most famous example of this, is Ravel's Bolero. Ravel himself played the main melody of what ended up being Bolero to one of his composer friends and said: 'This theme has an insistent quality. I'm going to try and repeat it lots of times without any development, gradually increasing the orchestra as best I can.'
Technically that is an example of dynamic tension - i.e just slowly cranking up the volume as the piece progresses, and as Ravel said, starting off quietly and basically getting louder and louder as each additional instrument comes in and joins with the preceding instrument in weaving the repeating melody around the snare drum which keeps going for the whole thing.
Having said that, the way the melody weaves in and out of the snare drum in a kind of hypnotic way does tend to drive it forward. All this leaves you thinking 'where the f*ck is this going?' as you listen to it for the best part of fifteen minutes. Then as a kind of musical 'f*ck you' joke at the expense of the listener, Ravel simply ends the piece with not much in the way of a resolution other than a big loud 'ta-da!'.
He should have called it 'How do you like them apples!'
Imagine replacing it with something entirely conventional - the unimaginative anti-climax would echo backwards all the way through the piece. You'd listen to it once and write the whole thing off as a very poor effort with no worthwhile ideas. (This wouldn't be entirely fair to it, but we humans are like that - once we write part of something off we stop looking for good aspects and just say "it's complete carp" without much qualification.)
But as-is, next time we hear Bolero, somewhere in our heads we are waiting, waiting, waiting for that discordant finale which smashes the hypnotic pattern. That is the brilliance of the work, really - for 15 minutes Ravel creates strong, slow-build tension by not creating tension!
https://youtu.be/kEdH5dU7ZKk?feature=shared
Can't see another post beating that for January's post-of-the-month prize!
The only thing I can think of saying is that in Hal's Eric Clapton thingy, at 00:16, over the E7 and D chords (the D is a IV not a VI btw), I'm not sure that's a C# - the note is bent up to a D; OK it's a bit flat and is probably somewhere between a C# and a D, but anyhoo the reason that works is because blooz doesn't mind being a bit flat on those squeezed notes.
(As you correctly point out the D is indeed the [edit] IV chord - senior moment there - will try harder next time!)
In a Beato video about playing bass, he specifically recommended that bass players avoid melody tones. That was an almost overwhelming statement to me because I usually think in chords and chord tones and I don’t know what “melody theory” is. Is the melody always a chord tone? Never a chord tone? How does a bass player know which chord tones to avoid if the melody is in the chord?
When I was forced to sing in choirs as a lad, I remember being in the bass section and we rarely sang a melody tone. It was always harmony. But was it a chord tone?
I need to start memorizing bass lines.
And from that advice, Beato obviously isn't a bass player. Playing bass, you generally resolve to a chord tone, very often to the root of the chord, and you do that in a structured way - typically the chord tone comes on a strong beat (but in some styles of music you tend to do the reverse). Either way, you do it deliberately and systematically.
Now if we were talking about the bass line in something like a string quartet, then we in a sense aren't "playing bass", we are simply playing the lowest voice on a four voice harmony. The "melody" gets shared around between all four instruments and at any one moment you often can't really say who "has the melody".
As others have said, there’s a whole host of musical factors that can affect the tension of a melody, not just notes (rhythm!). But seeing as you’re mentioning chord tones a fair bit…
There is a hierarchy of consonance and dissonance with melodic tones over and within harmonic context. If you were to compose a short melody over a simple C major triad, the safest notes choice would indeed be the chord tones. There’s a sense of gravitational pull towards the 1 3 or 5. Out of the remaining scale tones, 2 6 and 7 have more ‘colour’ with the 7th beginning to pull the ear with a slight sense of tension to go to the root. Finally, 4 is the scale tone with the most tension, as it clashes with the 3 in the chord. The 4th is often referred to as an “avoid note”. I don’t like this term, I like all options. I think “a handle with care note” is more appropriate. And it’s funny because the most dissonant scale tones over a C triad (in said key) the 4th (F) and 7th (B) serve a particular function…
https://youtu.be/t4pxrqVLGE0?si=v9DHypmP2wW_zn8Q
Anyway, is this perhaps by far without a doubt the least standard standard? Normally I can detect the melody from chord structures and progressions, but with this one I get nothing. The melody seems totally detached from what’s going on everywhere else.
¡Tensión!
The fact that there are so many versions of the song doesn’t help, even though it usually does with other songs (I like to make playlists of a standard and listen to it).
I'd recommend analysing the harmony and then the melody against the harmony. You may very well get insights by doing so that you otherwise might not pick up on.
