Another option is to get any standard expression pedal that has room for a toe switch and add it yourself. I have done that a few times and it is a really simple mod that only takes minutes to do.
For example: https://www.reddit.com/r/diypedals/comments/irvvid/donner_viper_mod_for_hx_stomp/
Maybe I'll just spend more time tinkering and seeing if I can get most of what I want from using extremes of the pedal position to switch things on and off.....
That's just taking the piss! It's such a simple product!
If its for bedroom/studio use, the m-audio £20 ones work perfectly fine with modeller's. No need for a 2kg lump of steel unless touring
It works for helix too, but it’s the most basic unit possible. No button, just up and down. Mine is a dedicated volume pedal which I use on every preset. I use the helix pedal for any effects.
